resistor(s) in ground paths to reduce hum, etc.
Old 28th April 2012, 09:11 PM   #11
CharlieLaub is online now CharlieLaub  United States
Originally Posted by jameshillj View Post
In David Davenport's article (Audio Component Grounding ...) that you have linked to, section 3.7 (Effective Interconnection Schemes) contains "Simple System of SLB Components" (3.7-3) where he has indicated that this is a viable technique of using Safety Loop Breakers in system connections.
In the above excerpt of your post, I believe that you mean "Group Loop Breakers" and not "Safety Loop Breakers". We don't want to anger other posters who may thing that you are advising that people defeat the safety ground!!!
Thanks for following up on the early posts and bearing with my difficult-to-understand description of the problem at hand. I actually don't have ground loop issues, but I wanted to try and further my understanding of these things.
I am still not clear on when the inserted resistors are "too much", e.g. their resistance is high enough to create new problems. There must be a sweet spot between reducing loop currents that cause hum and something undesirable as the resistance increases beyond 100 ohms...
-Charlie
Old 29th April 2012, 05:32 AM   #12
jameshillj is offline jameshillj  Australia
Sorry Charlie, thought I'd sent you a reply.
I think a lot of the difficulty when talking about the problem of "earth loops" isn't confined just to audio but occurs in every power distribution systems, be it domestic grip supply, electric trains, indusrty or hifi systems and the different engineers in the various fields do use a different terminology, and thus a lot of confusion.
Unfortunately, Dave D's paper does call it "Safety Loop Breakers" - Ah well ...
About the rersistor values, I can't actually add any better information, or theoretical reasoning, just anecdotes that illustrate the same "fudged design" as Sonic calls it - just an ol' power engineer here!
Perhaps AndrewT, SY, or other folks, can add some theory to answer your query.
Old 17th September 2017, 10:56 PM   #13
vargasmongo3435 is offline vargasmongo3435  Puerto Rico
vargasmongo3435's Avatar
Send a message via Yahoo to vargasmongo3435
hello guys I have a question on the power supply on the STAR GND can a wire be connected to chassis GND ? the image belongs to Mr. ST
Best Regards
Juan
audio fanatic only
Old 17th September 2017, 10:58 PM   #14
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Yes, and chassis ground to protective earth, all for safety reasons
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 17th September 2017, 10:59 PM   #15
thank you
Best Regards
Juan
audio fanatic only
Old 17th September 2017, 11:01 PM   #16
You're welcome
resistor(s) in ground paths to reduce hum, etc.Hide this!Advertise here!
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 04:50 PM
Resistor Noises: How to reduce them SeanPool Solid State 7 1st August 2005 06:40 PM
Can I reduce digital ground plane noise? fastcat95 Digital Source 7 12th May 2005 07:12 AM
Reduce NFB but keep noise/hum down? K-amps Solid State 12 17th March 2005 10:47 PM
Does a cathode bypass capacitor reduce hum? ray_moth Tubes / Valves 23 21st August 2004 02:38 AM
Copyright ©1999-2017 diyAudio
