My fuzz pedal project is behaving badly
Old 18th April 2012, 03:25 AM   #1
magnetman is offline magnetman  Australia
Default My fuzz pedal project is behaving badly
Hi all.
Hopefully a simple fix. I have a fuzz face PNP type circuit. it works really well with a 9v battery, however when I use a 9v plug pack problems start.
The issue is this. I have a single plug pack driving multiple devices. When all dc is plugged in it works (power to the devices in the chain). When I plug a 1/4" phono from fuzz to the little 9v amp input, power is cut. this happens with all devices in my collection. I had a thought that it is because of the positive ground the circuit has, but i cant work it out. no hair left too pull out.
cheers.
Luke
Old 18th April 2012, 10:00 AM   #2
epicyclic is offline epicyclic  United Kingdom
If you want to run it all from one supply youll have to convert your fuzz face to the NPN version (reverse the capacitors etc) or stick to using the battery . You cant ground the positive in one unit and the negative in another , run off the same supply rails then connect the 2 grounds together either accidentally or on purpose as you are shorting the positive to the negative ..............see ....fuzz face help .....thread in Instruments and amps for some related info .
Old 18th April 2012, 12:03 PM   #3
Simon B is offline Simon B  United Kingdom
I do remember seeing, some time ago now, an effects psu advertised with eight, independent, floating, 9v outputs, rather than the usual one.
This had two possible uses: Allowing positive ground effects, usually a pnp fuzzface to be connected, and elimination of ground loops. Not sure who made it.
Old 18th April 2012, 09:44 PM   #4
there are few companies out there that do them, what i don't like about them is they bring mains voltage to your feet. In live music situation this is hazardous (beer spillage, punters throwing water and so what at you) generally I like to keep all mains voltages on the back line.
I have in mind to make one that takes a plug pack power supply, say 24v (this is voltage requirement of one of my pedals) then split it out into and 18v and several 9v outputs. still thinking about it really not committed to sit and build yet.
cheers
Old 18th April 2012, 09:49 PM   #5
If one of your pedals needs 24v, either AC or DC, then I think you're going to run into the same problem, in a different guise if you start trying to derive other supplies from that.
Old 19th April 2012, 12:41 AM   #6
yeah, you are right! I dont understand enough currently to begin solving this problem.
The is obviously a way, others have done it.
My fuzz pedal project is behaving badlyHide this!Advertise here!
Help with mis-behaving Cambridge 540A J Wiggle Solid State 33 1st February 2016 10:34 PM
How to get good Fuzz from a Guitar-amp project. stigla Instruments and Amps 23 27th August 2012 12:28 PM
LM337 behaving strange??? deduikertjes Power Supplies 19 22nd June 2012 12:52 AM
CDM2/10 Behaving Badly Dave S Digital Source 71 26th May 2010 10:52 AM
Fuzz Face DIY: need more fuzz ThomasDIY Instruments and Amps 12 17th September 2009 03:06 AM
Copyright ©1999-2017 diyAudio
