Op-amp Upgrade
Op-amp Upgrade
Old 18th April 2012, 12:39 AM   #1
Ducs is offline Ducs  Canada
Default Op-amp Upgrade
I am looking into upgrading an opamp on my pc soundcard. Its an Asus Xonar DS. It has an onboard opamap socket with a TI's NE5532 DIP. I was thinking of either OPA627 or OPA827. Since NE5532 is a dual and both, OPA627 and OPA827 are singles I am planning to use a BrownDog board. I've heard good things about OPA627 - apparently it has a 'valve' sound. What are your opinions on the 627 and 827 ?? Is there anything else you would suggest ??
Old 18th April 2012, 12:58 AM   #2
KBK is offline KBK  Canada
opa2107 in dip form, might be a good choice.
827 and 627 will both require a 'brown dog' adapter, obviously.
"Extraordinary claims require extraordinary evidence." - Carl Sagan. Sometimes the claims aren't extraordinary. Sometimes the weakness of men's minds are the culprit. Mass mentality has nothing to do with obviousness or truths.
Old 24th April 2012, 04:26 AM   #3
whoops.
Only the opa827 requires the adapter to get to a DIP style mounting package, the OPA827 being available in MSOP-8 and SIOC-8 surface mount packages only.
OPA627 is available in the DIP-8 package.
Some folks claim they can hear the adapters, when they are used.
Old 24th April 2012, 04:45 AM   #4
kaos is offline kaos  United States
Not a big fan of the 627 or 827 myself. The LME49860, or the plethora of other part numbers National released it under, sounds better to my ear, and should be a direct plugin for the 5532.
Old 24th April 2012, 08:57 PM   #5
yah gotta watch out for that.
A 'which op amp?' thread on an audio board... is like a 'which oil for my engine?' thread on an automotive board.
Both have a penchant for dissolving into augmentative nightmares. For no good reason.
Op-amp UpgradeHide this!Advertise here!
Op amp upgrade Jason Hubbard Analog Line Level 2 23rd May 2010 02:59 PM
best choice for upgrade from LF353P OP AMP crippledchicken Solid State 9 27th August 2008 10:40 AM
Op Amp Upgrade In Audio Alchemy Ditb D/a arupg Digital Source 16 7th December 2006 08:28 AM
Denon dvm 3300 op-amp upgrade Htguy Solid State 1 8th August 2003 06:32 AM
15 year-old integrated - Op-amp upgrade Lenin Solid State 7 24th September 2002 08:41 PM
