Shields in internally balanced equipment
Old 17th April 2012, 11:22 AM   #1
dashbad is offline dashbad  Singapore
Default Shields in internally balanced equipment
I have searched and read numerous threads on grounding but not found an answer to this query.
I am planning a Control Room Monitor unit with input selection and volume control. I intend to keep the signal path balanced from input to output. This is to keep the signal as untouched as possible during normal operation.
I understand that it is recommended to connect the shield connections at the input and output to the chassis - thus making the chassis an extension of the shield of any incoming/outgoing cables. The Chassis will be aluminium.
Does this mean that I can run the balanced signal between PCBs inside the chassis as unshielded twisted pair without much issue?
What are/if any, the disadvantages with this approach? Should I be running shielded cables internally instead.
Signal wires will be kept well away from AC power and only likely to be close to low level DC.
Many thanks in advance
Old 17th April 2012, 07:22 PM   #2
epicyclic is offline epicyclic  United Kingdom
Connecting the XLR screen and using unscreened as your suggesting sounds OK to me but you will only really know by trying it .
For some very good info have a look at www.sound.westhost.com/articles/balanced-2.htm with very relevant info towards the very bottom ,figs 16 and 17.
Old 17th April 2012, 09:35 PM   #3
Simon B is offline Simon B  United Kingdom
The ESP page that epicyclic links to is excellent and if you want to indulge yourself in more, much of it by Bill Whitlock, author of the material on balanced stuff on Rod Elliott's site, have a look at
JENSEN TRANSFORMERS, INC. - APPLICATION PAPERS AND SCHEMATICS
JENSEN TRANSFORMERS, INC. - APPLICATION SCHEMATICS
possibly particularly
Build the "Hummer" to Find "Pin 1 Problems" in Equipment (17KB PDF)
Proper Grounding Inside Equipment Avoids Ground Noise Coupling (aka "Pin 1 Problems") (15KB PDF)
Be warned, this site induced download frenzy in me when I went there, thought I'd grown out of that some time ago.....
Old 17th April 2012, 09:40 PM   #4
DF96 is offline DF96  England
If there is an interference source (e.g. PSU) within the box then you need to be careful. Of course, your balanced line receivers will reject common-mode noise but not differential noise.
Old 17th April 2012, 09:45 PM   #5
Wise words from DF96, as usual. Power supply rectification / mains noise ingress being possibly the most likely areas to watch.
Old 18th April 2012, 03:21 AM   #6
Thanks for the responses. Very useful. So it would seem that correctly grounding any equipment inside the case is key and mains/PSU noise will be of most concern inside the case.
How does this noise manifest itself in signals inside the case? Is it RFI that I can remove by shielding signal cables (with shield unconnected at either end)?
If all signal cables are twisted pair is it not likely that any injected noise will be common mode? In what situation might it be differential?
Old 18th April 2012, 10:37 AM   #7
Mains and its harmonics are likely. Could be coupled via capacitance or magnetically. Good twisting will reduce magnetic coupling, which will be differential-mode. Good common-mode rejection will reduce the effect of capacitive coupling.
Shields in internally balanced equipmentHide this!Advertise here!
Blown fuse when power on without connections internally hew128 Digital Line Level 9 30th August 2009 04:18 AM
Neopro5i - opinions on how to connect to internally topher_m Multi-Way 2 8th May 2009 02:18 PM
Internally Curved Austin Horn dzzmiller Full Range 11 6th March 2009 01:18 PM
Tube Shields korneluk Tubes / Valves 1 17th December 2007 04:31 PM
Balanced Mic Preamp, Transistors...and Studio Equipment iCebReakEr409 Solid State 4 28th December 2003 08:03 AM
