Need help with the NE5543N opamp - Page 8 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 7th May 2012, 07:37 PM   #71
Ok i replaced the 701\702C in new one
and test again both chanel allmost identical with slightly change i think it is normaly and verery thing ok ,
I waiting to relay board kit , after that I will uplaod video to youtube
thanks every one may god bless you
Old 8th May 2012, 06:27 AM   #72
Mooly's Avatar
It's common for volume controls to mistrack at very low levels. If you work the difference out as a figure in db's then it looks much better. Even the 45/60 low level result is better than 2.5db matching. The 70/80 result just over 1db mismatch.
Good channel matching in pots is a problem even today and one reason why pots such as ALPS are often used... but it comes at a price.
Old 8th May 2012, 06:31 AM   #73
eventualy it was the volume control , the balance is ok .
I order a new one from ebay
Old 8th May 2012, 06:43 AM   #74
Mooly's Avatar
That's good
Thanks for the update.
Old 24th November 2012, 03:47 PM   #75
hi all , well the the preamp is woorking good until now
i want to add to it "Bass Boost "
you know how is the best way to do it ?
i want the the bass ' tight ' and ' strong '
thanks
Old 24th November 2012, 05:59 PM   #76
Mooly's Avatar
You can't easily modify this to give a boost to just the lower frequencies, it needs a major reworking. Something like this kind of thing maybe,
Stereo Preamplifier with Bass-boost - circuit diagrams, schematics, electronic projects
Old 24th November 2012, 06:06 PM   #77
It is very complicated and diferent from my op preamp
you have maybe example of bass boost that is simple but accurate ?
Old 24th November 2012, 07:01 PM   #78
Mooly's Avatar
Not really... that's about as simple as you can do it I'm afraid. I can't just think of anything else.
Old 24th November 2012, 07:21 PM   #79
ok thanks molly ,but i didn't understand how to modify my preamp .
can you please draw it ? thanks .
Old 25th November 2012, 09:04 AM   #80
Mooly's Avatar
You can't just "modify" it to do what you want. It's a either a total redesign or an add on circuit to go before or after the preamp. To boost just the bass and leave the mid and treble alone needs an active circuit using opamp. You can't do it by just adding a couple of parts to the existing design.
Here's another one,
Bass Booster
they are all based on the same principles.
May I have your ideas for this opamp>LCR>opamp>tube>output transformer phono stage Witti Analogue Source 17 31st May 2013 03:57 AM
Which opamp was used for the Adcom 6AA opamp ? gaetan8888 Digital Source 3 20th December 2010 07:17 AM
Help about OPAMP nandax Chip Amps 9 28th October 2008 02:34 PM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
Regulate the psu of a power opamp with a similar power opamp? Franz G Chip Amps 34 19th October 2004 10:49 AM
Copyright 1999-2017 diyAudio
