Need help with  the NE5543N  opamp Need help with the NE5543N opamp - diyAudio
Old 16th April 2012, 01:55 PM   #1
WhiteRhino is offline WhiteRhino  Israel
Default Need help with the NE5543N opamp
Hi , I bought the NE5534N opamp . from here
Find 2pcs NE5534N Dual Low Noise OP Amplifier IC m on eBay Global Buying, with worldwide deals on items in all your top categories
Now just to be sure , is this opamp is dual ? can you find me the datashit ?
i found data **** for the 5543 which is single . but for the 5543N which is dual i can found ?
i want to build a simple active stereo preamp I will be glad if you recommend for me a nice schema for that .
thanks and have a nice day
EDIT : ok now i see that the 5534 is a single opamp .
can some one give me a draw of nice preamp design for this opamp ?
Old 16th April 2012, 09:28 PM   #2
mickeymoose is offline mickeymoose  Canada
What do you want to amplify and to what? Input/output levels and devices? E
Old 16th April 2012, 09:33 PM   #3
i want to build stereo preamplifier ,
the input is line level like cd\tape and the output will go to stereo poweramp
i want the preamp to have gain of X5
Old 17th April 2012, 12:44 AM   #4
dchisholm is offline dchisholm  United States
dchisholm's Avatar
There are some who would disagree, but in my opinion the NE5534A is an excellent value for experimenting in general audio applications. You'll have to spend a lot more to get significantly improved performance in most applications; usually there will be other factors (besides the choice of opamp) limiting the overall circuit performance.
There are several basic preamp projects shown on Rod Elliot's "ESP Project Pages" at < http://sound.westhost.com/projects-2.htm >. I haven't actually built any of these specific circuits, but they are quite similar to other circuits I HAVE successfully built. In general, the NE5534 should work in any of his circuits, though you will have to add a compensation capacitor between pin 5 and pin 8 to make sure the '5534 behaves nicely at the low gain levels used in Elliot's circuits.
(A capacitor value of 22 pF should be quite acceptable in any of the circuits shown; lower values down to 10 - 12 pF may give measurable improvements in bandwidth and transient response. No additional capacitance should be necessary if you modify Elliot's circuits for gains of 3 or more.)
I'm sure that if you seed the DIYAudio "Search" function with "NE5534" or "NE5534A" you will uncover MANY other designs specifically using those chips.
Dale
Old 17th April 2012, 11:06 AM   #5
I have a strange problem , I attached 20V+ to pin 7 and ground (0 ) to pin 4 .
I messured volt on pin 7 and he has 0 DC volt and 1.5 AC volt .
may be there is problem in my circut I cant understand what is it
Old 17th April 2012, 11:15 AM   #6
5534 is a single.
PIN7 is +ve
PIN4 is -ve
max + to - is 44V
PINs 1, 5 & 8 are not conventional. Be careful how you connect these.
Download the datasheet for your manufacturer and follow their recommendations for decoupling and compensation and gain.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th April 2012, 11:22 AM   #7
Mooly's Avatar
Post the circuit you are using.
Old 17th April 2012, 11:24 AM   #8
Thanks for the replays could some one draw for me recommeded circut ?
Old 17th April 2012, 11:26 AM   #9
You have already been given a link.
You have already been told how to search.
regards Andrew T.
Old 17th April 2012, 11:32 AM   #10
OK sorry for the poor quality but this is the schematic
Need help with  the NE5543N  opampHide this!Advertise here!
May I have your ideas for this opamp>LCR>opamp>tube>output transformer phono stage Witti Analogue Source 17 31st May 2013 03:57 AM
Which opamp was used for the Adcom 6AA opamp ? gaetan8888 Digital Source 3 20th December 2010 07:17 AM
Help about OPAMP nandax Chip Amps 9 28th October 2008 02:34 PM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
Regulate the psu of a power opamp with a similar power opamp? Franz G Chip Amps 34 19th October 2004 10:49 AM
Copyright 1999-2017 diyAudio
