Poles and throws?
Poles and throws?
Old 16th April 2012, 06:12 PM   #11
DF96 is offline DF96  England
Rotary switches are available from almost any electronics supplier. Quality may vary, of course. What is it that you can't find?
Old 16th April 2012, 08:45 PM   #12
Etocynned is offline Etocynned
Lol, rotary switches!
Altec Lansig computer speaker amp, Paradigm atomss, Altec computer sub, Windows PC source
Old 16th April 2012, 08:51 PM   #13
Ok so i found 2 on parts express, 2 pole 6 position.
to make an input switcher would i use shorting or non shorting.
just a dead simple line level rca switchbox for the input on my i12.
Old 16th April 2012, 09:12 PM   #14
I assume 'shorting' means Make Before Break (MBB), and 'non-shorting' means Break Before Make (BBM) - some of these terms vary around the world. For an input selector you want non-shorting or BBM. Most switches are of this type. Using the wrong type probably won't do any harm, provided all your sources are well-engineered and can cope with a brief short circuit.
Most rotary switches have an adjustable 'stop', so you could buy a 2-pole 6-way and set it to do 2-pole 3-way. You may have to be careful to set the stop at the right end, otherwise your knob might not line up with your panel markings.
Old 16th April 2012, 10:03 PM   #15
Ok that makes sense.
So im seeing dead simple as 4 pair input rca's and one pair output rca.
The input selector knob mounted on a front panel and the rcas on a rear panel.
Perhaps some ofc 24guage copper wire in between.
Bob's your uncle?
Old 16th April 2012, 10:07 PM   #16
Yes, although I am personally not into exotic conductors.
Old 17th April 2012, 12:03 AM   #17
So no carbonized yaks wool helical braided vacum dielelectric detuned hermaphroditic connector type stuff?
Old 17th April 2012, 10:36 AM   #18
Yaks wool is no good as a dielectric, as it becomes lossy above 5kHz.
Poles and throws?Hide this!Advertise here!
Poles or feedback 101 tvrgeek The Lounge 9 16th January 2012 01:51 PM
little girl throws down tomtt The Lounge 13 23rd June 2011 09:47 PM
magnetic poles of a speaker motor Clipped Subwoofers 7 16th January 2009 11:15 PM
Jensen 4-poles capacitors for sale hc167 Swap Meet 3 19th September 2008 07:32 PM
Transfer function. Poles not where expected Raka Multi-Way 35 29th July 2008 01:20 PM
