| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#11 |
Yes, either a dry joint or a crack in a PCB trace. If you are using modern lead-free solder then I understand that dry joints and good joints can look identical (I always use the old 'poisonous' solder). If you showed us the circuit we could probably tell you where to look for the problem.
#12 |
I'd look for an op amp input fed by a capacitor, that also has a resistor to ground, or to some other circuit node that direct current can flow out of.
If that resistor is not properly connected, the small bias current flowing out of the op-amp input charges up the capacitor and hey presto, the very fault you describe. Probably, learn to solder properly, you've got a dry joint at the end of a resistor. Before you fix it, look at it, see how it looks different from good joints. As DF96 says (and I paraphrase a little) "use proper solder". As DF96 also says, possibly a crack in a pcb trace. They can be very fine indeed and still be an open circuit. But my money's on a dry joint. Last edited by Simon B; 15th April 2012 at 10:33 PM. |
#13 |
Cracks in PCB traces can be obviated by tinning all of the PCB tracks with solder, but doesn't work that well for high current tracks. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#14 |
I couldn't find any obvious bad joints, but I "untangled" some blobs where lots of leads met. On the third one the buildup disappeared, and the output is DC-free!
![]() Thanks a lot to everyone, and especially to Simon B. I went untangling the capacitor junctions first. The troubled capacitor was closer to the output, but was a part of the feedback loop. It's the rightmost C2 in the schematic attached. There are 'before' and 'after' pictures, if anyone's interested. DF96, sorry for misleading, but I didn't realize at the time. As you can see, the before picture doesn't have obvious 'bad' joints, just lots of evil blobby ones. Guess I underestimated their evilness. My next project will be adding a high pass filter before the Linkwitz Transform. My speakers have Visaton W170S woofers, and the LT extends them to Q=0.7 and F3=30Hz. They don't do 30Hz like I expected. Distortion is bad, and cone movement is scary with anything except music. My room needs less deep bass anyway. Going to use a 1st order high pass at 50Hz. If I mess that up, I'm gonna end up with a flat forehead, from a wall.
#15 |
My bad, the affected capacitor is C3, not C2.
#16 | |
As I said:
| Will a Linkwitz transform...transform the driver? | AllenB | Subwoofers | 20 | 17th May 2010 10:24 PM |
| Greater than 20dB gain at DC with Linkwitz Transform - bad? | Jim85IROC | Subwoofers | 14 | 25th November 2006 03:49 PM |
| linkwitz transform | peace brainerd | Subwoofers | 4 | 31st January 2006 01:13 AM |
| Linkwitz Transform | ding | Multi-Way | 10 | 11th July 2004 09:55 PM |
| Linkwitz Transform? | Aunkst | Chip Amps | 6 | 28th March 2004 11:59 PM |
