Humorous mistake in Douglas Self Active Crossovers book - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 7th April 2012, 10:35 PM   #1
Default Humorous mistake in Douglas Self Active Crossovers book
Found on page 344:
You may object that putting four 1% resistors in series means that the worst-case errors can be four times as great. This is obviously true -- if all the components are 1% low, or 1% high, the total error will be 4%.
Oops! The total error will be, at most, 1%.
Suppose we want a 400 ohm resistance. If we put four (100 ohm, 1%) resistors in series, the maximum possible series resistance is (101+101+101+101) = 404 ohms. The error is ((404 - 400) / 400) = +0.01 = +1%. Likewise the minimum possible series resistance is (99+99+99+99) = 396 ohms, for an error of -1%. I am tempted to write "obviously!" but that would be unkind.
Last edited by Mark Johnson; 7th April 2012 at 10:35 PM. Reason: typo in page number
Old 7th April 2012, 10:50 PM   #2
jan.didden's Avatar
I learned something today! Thank you!
jan didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 12 is out! Check out my Autoranger and SilentSwitcher
Old 7th April 2012, 11:05 PM   #3
Leon08 is offline Leon08  Germany
Banned
But he mentioned that probability of this occurring is very, very small. This means that he himself does not believe that it can actually happen.
Old 7th April 2012, 11:44 PM   #4
Speakerholic
Cal Weldon's Avatar
Good one markj. I could have read right past that one and not picked it up.
Thanks.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 8th April 2012, 10:10 AM   #5
gk7 is offline gk7
Yes, the probability that all parts error in the same direction is very small. In fact you get a smaller error in percent for combined parts in most cases.
Old 8th April 2012, 10:47 AM   #6
dchisholm's Avatar
That is true if the value errors are truly uncorrelated from part to part, and uniformly distributed across the tolerance window. In some situations that's probably a good assumption.
But if all 4 parts come from the same production batch . . .
  • Produced at the same time under the same ambient temperature, humidity, atmospheric pressure, etc
  • From the same batch of raw materials, with the same level of impurities
  • On the same machine, with the same degree of wear, misalignment, calibration errors, etc
. . . then I would expect the 4 parts are likely to have correlated tolerance errors, and add all in the same direction. The 4 parts may, in fact, be much more closely matched in value (whether that value is high or low, positive or negative, in the tolerance window) than you would expect from selecting 4 parts "at random" from a group with variations uniformly distributed across the tolerance window.
Dale
Old 8th April 2012, 12:01 PM   #7
Self discusses this issue of increasing accuracy with increased numbers of parts.
He also gives some space to selecting the multiple parts to give a guaranteed tolerance that is considerably better than the basic component tolerance.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 8th April 2012, 11:50 PM   #8
tvrgeek is offline tvrgeek  United States
Actually, it is more likely they are in the same direction if they were made at the same time under the same process. That is the holy grail of manufacturing, consistency. Still, pretty big slip. We do need to always give an author a bit of slack sometimes. These are not reviewed academic papers, but a ton of work.
Old 8th April 2012, 11:51 PM   #9
I do wonder if worrying about tolerance of 1% resistors matters when we are dealing with transistors and caps.
Old 9th April 2012, 12:30 AM   #10
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by transistormarkj View Post
Oops!
1.014 ~1.04
Slipe of the Pipe.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
The design of active crossovers- Douglas Self wants your opinions DouglasSelf Analog Line Level 293 21st May 2016 12:33 AM
Douglas Self's Active Crossovers book forr Analog Line Level 8 31st December 2010 06:20 PM
New Douglas Self Book blmn Solid State 7 22nd July 2009 07:00 PM
Failed Humorous Audio Projects jackinnj Everything Else 1 13th June 2005 05:19 AM
book-audio power amplifier by Douglas Self mikee12345 Solid State 8 16th November 2003 02:16 AM
Copyright ©1999-2017 diyAudio
