Selector switch - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 3rd April 2012, 03:55 PM   #1
Default Selector switch
Hello.
I am putting together a volume buffer, and I need an allright selector switch, either rotary or toggle for 3 inputs. What specs am I looking for then? Any suggestions?
I wanted the pcb from glassware but its allways sold out...
"Simplicity is the key to brilliance"
Old 4th April 2012, 10:49 AM   #2
strip the switches/selectors from an old integrated amplifier.
or
buy a 12segment rotary. They can be configured as 12W 1pole, 6way 2pole, 4way 3pole, 3way 4pole and 2way 6pole (very uncommon).
You need the 3way 4pole.
The two spare poles could switch indicator LEDs or something.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 4th April 2012, 12:37 PM   #3
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Why not to use a digitally controlled switch: a CD4053 and a CD40162/3 and a two push buttons switch. It´s easy and noiseless. Only need +-5V @ 1mA
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 4th April 2012, 03:11 PM   #4
A switch does not need a power supply..even simpler
Besides, I like the looks.
Old 4th April 2012, 04:19 PM   #5
In my audio set, the 8 inputs are selected via a HCF4051 (one per channel), and they work fine, no pops, no false contact, etc. And a simple frequency counter and two buttons acting as "up" and "down" in the #of input selected, a debouncing cap. are the best solution. Power is requiered because the HCF4053 acts like a 8 position 1 pole relay, and only 100R between "contacts".
Simply: extraordinary.
Selector switch questions Frosteh Analog Line Level 3 18th August 2011 03:49 PM
Input Selector Switch chrismercurio Parts 5 30th September 2010 04:54 AM
A/V Selector Switch Navin_R_Johnson Everything Else 5 8th April 2007 05:16 PM
A Selector Switch? JohnnyBoy Class D 5 15th February 2006 03:33 PM
Selector switch Navin_R_Johnson Parts 8 29th January 2006 07:12 PM
Copyright ©1999-2017 diyAudio
