Go Back   Home > Forums > Source & Line > Analog Line Level
Old 27th March 2012, 08:59 PM   #1
Default Analog Signal to fire Contact Closure
Hello all,
I'm new to the forum and was hoping someone could help me with a fairly basic first project.
I have a video streamer which fires wipes across a television screen. I am looking to find a simple project board I can assemble to take an analog line level signal (1kHz Tone) and fire a contact closure or relay. The streamer has two terminals simply marked GND Trigger and after jumping it with a paper clip I am reasonably satisfied it's a contact closure. When I attached it to an unbalanced output on my audio interface it just would continually fire wipes.
I know a simple device should cost too much or be too difficult to solder together. I am not sure what voltage I am dealing with. Any guidance in the right direction would appreciated as right now I am lost on wikipedia.
Thank you!
Josh Vamos
Old 27th March 2012, 09:14 PM   #2
use a 4n32. Connect one end of a 1,000 ohm resistor to the center pin of the audio out. The other end of the resistor goes to pin 1. Pin 2 goes to the shell of the audio out connector. You can ignore the ring contact. Pin 5 goes to trigger and pin 4 goes to ground.
http://www.vishay.com/docs/81865/4n32.pdf
Old 27th March 2012, 09:46 PM   #3
Thank you very much for your input!
Is this along the lines of what you meant?
Thanks!
Josh
Old 28th March 2012, 12:45 PM   #4
Thanks!
Josh
I am not the best at sketching things up.
Old 28th March 2012, 01:34 PM   #5
Yes, you can test the circuit with a battery for input. 9V would be fine. (+ to resistor) If it doesn't trigger switch the sweep terminal connections.
Old 28th March 2012, 04:24 PM   #6
esp did a couple of projects using analogue as trigger input.
Old 28th March 2012, 04:49 PM   #7
Default ESP Projects
Hey thanks! I'll search for posts by ESP
On another note just got back from my local electronic hobby shop and they only had the 4n31 and the 4n37 and 4n38.
Are those a suitable substitutes?
Thanks!
Josh
Old 28th March 2012, 05:22 PM   #8
How does one SWEEP a connection?
The ESP circuit seems like it would work but I would need to modify it to remove the delay. I only want the switch open when a short audio signal is sent out. Also having it trigger on every cycle would not be ideal.
Not really sure how to go about wiring this more involved board. Anyone make ESPs circuit?
Old 11th April 2012, 07:02 PM   #9
Hey Simon 7000 the just got the part. Going to pick up the resistor and the project box with a board...
Will report back.
Good Lecture Series: Electronics For Analog Signal Proc. cowboy99 Everything Else 0 17th December 2009 07:49 AM
Turning a small AC analog signal into DC HankMcSpank Solid State 8 22nd April 2009 01:39 PM
Thread Closure - Another Alternative PB2 The Lounge 63 23rd September 2008 01:28 PM
IDE CD-ROM to sound card signal - digital or analog ? percy Digital Source 6 6th August 2005 02:47 PM
Does digital data inverted results in analog signal inveted? Tubeee Digital Source 27 7th June 2005 12:34 PM
Copyright ©1999-2013 diyAudio
