Cello Palette Style EQ Design (was High End Tone Control)...
View Poll Results: If you where to build a Cello Palette functional clone, what technology do you want?
I want a Software Palette, Analogue EQ is SO 20th Century 8 16.67%
I want a purely passive EQ to which I want to add my own input buffer and output amplifier (MPPJBTS) 9 18.75%
I want a Minimalist discrete EQ using Tubes (ZenEQ derived from the "East German EQ") 15 31.25%
I want a Minimalist discrete EQ using Solid State (ZenEQ derived from the "East German EQ") 22 45.83%
I want Op-Amp's with parallel and summed bands (e.g. NitePro EQ3D) 5 10.42%
I want Baxandall Sections with Op-Amp's connected in series (e.g. Carl_Huff) 3 6.25%
Multiple Choice Poll. Voters: 48. You may not vote on this poll
Old 28th March 2012, 04:43 AM   #11
EUVL is offline EUVL  Europe
> It was designed in East Germany in the late 70's and remains somewhat legendary for it's sound quality. It avoids the use of looped feedback, which similar western Pro-Audio design already used in massive amounts routinely. I can attest to the sonics of this type of EQ, I used it extensively.
For a High End solid state design, I would have thought that one would want to at least get rid of the coupling caps ??
Patrick
xen-audio.com
Old 28th March 2012, 04:52 AM   #12
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Originally Posted by jameshillj View Post
As I understand this, the primary duty of the "Tone Stack/Control" is to correct recording anamolies but my speakers fall off pretty quickly below 34Hz, would it be better to move the lower 20Hz filter up to at least 34Hz for my system? And the next speakers I have in mind require the Link Transform eq (the B2 alignment, closed box design and would this conflict with this tone control design?
One could include suitable circuits after the actual control, such a combination of Speaker LF EQ and Highpass. I would not as such change the Centre frequencies of the EQ.
Having to work with a "Sea of Knobs" for years, it's not something I want to do at home - you just don't bother after a while.
It depends, I find I did when I used a Behringer DEQ in a similar style/application... The use must be quick, intuitive and easy, the EQ must be easily available.
Ciao T
Old 28th March 2012, 07:33 AM   #13
Why? As I routinely work with Tubes I have no irrational fear of coupling capacitors. Often, but not always they are a better choice than the direct coupling alternatives, which in actually still have coupling cap's, but so to speak "hidden from sight".
I notice Papa Pass's "Zen" range also has coupling cap's...
FWIW, the point is not to copy the East German design exactly, but to use the principles embodied. It would be possible to make a fully DC coupled circuit using rail symmetrical folded cascodes. But this would need a DC servo which I find most of the time worse than a high quality coupling cap. Complementary FEt's that are suited are also becoming hard to find. And I'd rather like to keep a level of simplicity that parallels the Pass B1.
I am sure what I can do with eight or nine J-Fets or less if I add some inductors and a handful of resistors and capacitors can be extended into something that requires over 30 Op-Amp's and offers less functionality and worse subjective sound quality, but I'll leave that sort of thing to those who have made it their life's work.
Ciao T
Old 28th March 2012, 11:51 AM   #14
Somehow I knew you were going to say this.
Patrick
xen-audio.com
Old 28th March 2012, 11:57 AM   #15
BTW if I understand the circuit correctly, it might be simpler to do this fully balanced input / output if direct-coupled.
Patrick
xen-audio.com
Old 28th March 2012, 12:19 PM   #16
gk7 is offline gk7
Great project; some questions:
I take your point that one can use a high pass filter after the EQ
(adds another stage though) and cello uses 20Hz too, but if I have for
example a ported box tuned to 40 Hz, I would not expect any useful output at 20Hz while
probably some adjustment at 40 Hz would be nice to have. The East German EQ
uses 63 Hz (probably a bit high) and the Neumann W491 45 Hz.
Are there plans to have the lowest center frequency adjustable,
letīs say 20-40 Hz ?
You mentioned the use of FETs, which do you have in mind (so we can
buy some as long they are available) ?
Old 28th March 2012, 02:55 PM   #17
Gopher is offline Gopher  United Kingdom
How is this thread any different from the other one? It's already turning into a talking shop with everyone putting their bit in but nothing getting decided. There'll be 10 or so pages of this then it will fizzle out like the other thread.
Oh and Thorsten - I did make concrete suggestions. Look again. If you want part numbers how about OPA627 with a National buffer or the AD 811 or AD815 if you want to use multiloop.
Old 28th March 2012, 05:11 PM   #18
Folks,
I had the chance today to run the "ZenEQ" concept through Tina-Ti. This is not necessarily meant to be a final design, rather a quick study how a simple circuit may perform.
This reminded me that if we require a more or less proportionate boost in dB vs. rotation we need to use potentiometers that are "S" curve, not linear. These are hard to get these days.
If using linear pots then the adjustment range gets bunched up towards the extremes. This is not necessarily a bad thing, as it makes very small adjustments very precise, the downside is that if we need a lot of correction we are left with very little usable travel.
If using switches as controls this is of course of no consequence at all, as we simply can select the correct resistances to give correct dB/vs. Attenuation.
Attached is Tina-Ti File I used (needs latest version) and some simulation results, all using 10K//1nF load. I am not sure how accurate the models buld into Tina-Ti are etc., but it would seem okayish for ballpark.
I would specify 2SK170 BL or V for the circuit, Tina-Ti lacks the model, so I made up a compound from 2N3819 & a PNP BJT, 2SK170 will show worse THD. I am for now showing ideal chokes, they can be replaced by gyrators, but I lack the time right now. For the LF choke 2H with < 120 Ohm DCR are needed, I do have a few such around, so we know they can be made.
The schematic looks like this:
Cello Palette Style EQ Design (was High End Tone Control)...-zeneq-gif
The curves produced by stepping the pots in 10% intervals (this is equivalent to rotating linear pots 10% of the rotation for each step):
Cello Palette Style EQ Design (was High End Tone Control)...-compound-gif
The frequency response with controls perfectly centred (impossible with pots) looks like this:
Cello Palette Style EQ Design (was High End Tone Control)...-frequency-response-gif
The LF rolloff is a result of the 2.2uF coupling capacitors shown. I habitually use this value, it works fine IME.
To illustrate two interesting EQ results, here what it looks like with all controls set halfway towards maximum cut from neutral:
Cello Palette Style EQ Design (was High End Tone Control)...-controls-0-5-gif
This illustrates rather well how the various bands combine and with a weighting that is similar to the ISO Equal loudness peaks and through...
And here a EQ setting that can help with modern overproduced recordings, by cutting back presence and "kick" bass, and dialing the extremes up, all just a touch:
Cello Palette Style EQ Design (was High End Tone Control)...-anti-presence-eq-gif
The required pot settings for this (0 = centre, 0.5 is half way between zero and the respective end, linear pots assumed) are:
15Hz = +0.5
120Hz = -0.5
500Hz = +0.2
2KHz = 0.0
5KHz = -0.8
20KHz = +0.6
Here harmonics for 1V out which adds up to 0.005% THD according to Tina-Ti:
Cello Palette Style EQ Design (was High End Tone Control)...-thd-1v-gif
and for 4V out which adds up to 0.05% THD according to Tina-Ti:
Cello Palette Style EQ Design (was High End Tone Control)...-thd-4v-gif
Clipping (1% THD) is at 5V.
Tina-Ti has a seriously funky way of showing noise, anyway, it works out ot -120dB unweighted re. 1V, which seems too good to be true. Still, might be on the money:
Cello Palette Style EQ Design (was High End Tone Control)...-snr-1v-gif
I hope all of this gives people some ideas for the "ZenEQ" and what sort result could be possible, to see if it is worth proceeding. To me the performance looks acceptable, we can get better measured results using Op-Amp's, but I doubt the sound will be improved.
Ciao T
Old 28th March 2012, 08:10 PM   #19
That is probably my fault. I refuse "to lead" and to be the one who lays the down guru style on how it can only "one way, this way and no other". I'd rather people find THEIR way. Hence i gave many options and ways.
Anyway, what I can contribute for now is on the table. True, I assume that there will be some of the least common of all senses applied when using the circuit I suggest, no attempts to drive headphones directly off the output of the EQ and other such sillyness.
Anyone wants to do something Op-Amp based instead, on a similar level, please chip in...
Ciao T
Old 28th March 2012, 08:32 PM   #20
Carl_Huff is offline Carl_Huff  United States
ThorstenL,
Please continue working up your FET & inductor solution. I've got a stash of suitable inductors leftover from the old days when I had an Auditronics 36 Grand mixing console. The EQ in that console was the reason that I kept it so long. I still have a stash of parts hoarded away. I have stash of FETs as well. If you complete the design I will be sure to build it.
Best Regards,
Carl Huff
Cello Palette Style EQ Design (was High End Tone Control)...Hide this!Advertise here!
Cello Audio Palette Nrik Analog Line Level 70 6th January 2014 06:00 PM
Best chip for digital tone control in high-end preamp ? bongo1 Parts 11 18th June 2013 02:12 AM
High End Tone Control EUVL Analog Line Level 144 1st April 2012 07:11 PM
Tube eq or tone control - how to design it? marz.tv Tubes / Valves 5 20th July 2009 01:01 AM
Cello Palette voltage change? young_pup Solid State 3 27th September 2006 11:23 PM
Copyright ©1999-2017 diyAudio
