Where is the point of diminishing returns with caps in passive crossovers?
Old 26th March 2012, 07:46 PM   #1
PDXMike is offline PDXMike  United States
Default Where is the point of diminishing returns with caps in passive crossovers?
I'm replacing the caps in the crossovers of my well known brand 3-way horn-based speakers. From what I have been reading, I believe that the low pass part of the crossover is a 2nd order, involving a 3mH inductor in series and a 47uF cap in parallel. The original cap is a non-polar electrolytic. My understanding is that it's function is to "bleed off" any high frequency signal that isn't filtered out by the inductor. When I've run the values through various on-line calculators it seems that the crossover point is around 400Hz (still hazy on whether this is the 3, 6 or 12dB point). FWIW, I think the values that result are bsaed on the Litz-Riley type, although I could be wrong.
So, my questions are:
1) Am I understanding this correctly?
2) Does the cap have any other function besides filtering out higher frequencies?
3) Besides "sound quality" and variable reactance with temperature and frequency (but, does this occur at anywhere near audible levels?), is there any specific advantage to replacing the fairly cheap electrolytic cap with a much more expensive poly cap?
4) My reading on the metalized film caps vs. film and metal foil caps (e.g., data sheets) indicate that the plate/electrode layer of the former is on an order of 250 times thinner (.02 vs. 5 or more u) and at least one writer raised the issue of lower resistance in the plates of the metalized film caps (see section 2.4) Capacitor Characteristics:
One thing that may be very important for passive crossover networks is the material used for the 'plates' of the capacitor. Metallised film caps may not be the best choice because of the resistance of the film itself. The film is usually extremely thin, and it may not have a low enough resistance to allow the full current required. I have not experienced any problems with this, but a film and foil type is more suited to high current operation than a metallised film construction. This topic is mentioned on capacitor manufacturers' websites, and I recommend a search if you want more information about current handling capacity.
Of course, I have not been able to find a sanely priced 47uF 100V film and metal foil cap, so the main question boils down to:
Should I bother spending a minimum of $12.55 per polypropylene metalized foil cap (Dayton), or is replacing the electrolytic cap with film a case of reaching the point of diminishing returns (vs. making listening environment changes, etc.)? Is there a significant (measurable physical performance) difference in how the two types of caps perform in this particular function?
BTW, I'm replacing the other caps in the crossover with NOS non-boutique film and foil caps (Wesco 32M 1.0 100V with 1% tolerance that measured well within 1%) and some 277P 1.5 uF 200V 10% orange drop style caps that I haven't received yet. I couldn't find any references to 277P caps, but the model number was similar to other known foil caps, so I gave it a shot.
Also, I'm still pretty much a newbie with practically zero training in electronics or even electrical theory (I still have trouble with the metaphors I've seen for Voltage - voltage is pressure? So, voltage is metaphorically like the amount of water pressure in a garden hose, pressure washer, and ? Isn't that directly related to resistance, then? What is the force operating? I think I get current - it's the amount of electrons flowing, right?) So, if anyone has any other metaphors I'd be glad to hear them.
Here are some of my audio biases:
  • I don't really buy into the idea that boutique caps make an quantitatively better difference vs. well made generic caps of the same construction.
  • I do have some training in human perception, and I'm very much aware of the ideas of the detectability of differences in signals (my recollection is about 3% for untrained observers and lower for experts) and accommodation (as you grow used to an often heard signal your brain gradually shifts it into a "background" mode ).
  • I think that "different" does not necessarily mean better or worse.
  • I also have fairly extensive training in the cognitive sciences, and am well aware of the various biases the people use in evaluating their environment.
  • I think that these factors explain much of what is being described bu people when talking about the tone qualities of electronic components
Lots of questions here, and yes, I've completed lots of searches already.
Thanks,
Mike
Old 26th March 2012, 08:05 PM   #2
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
No , electrons don't flow . It's the magnetic field that moves .
Old 26th March 2012, 08:33 PM   #3
DF96 is online now DF96  England
Yes, electrons do flow. However, in most cases it can be unhelpful to think in terms of putting water in one end of a hose and getting the same water out of the other end after a while. Instead, think of the hose already being full of water so you put a bit of water in one end and it pushes some water out of the other end almost immediately.
Old 26th March 2012, 08:52 PM   #4
SoNic_real_one is offline SoNic_real_one  United States
Pressure (psi) - Voltage (volts)
Flow rate (gallons per minute) - Curent intensity (ampers)
Diameter of hose - Conductor diameter
Water vane (strangulation that oposes water flow) - Resitor (opposes the curent flow). Across the vane you have a head loss (pressure drop) for a certain flor rate. Across a resitor you have a voltage drop for a certain curent.
A tank with two inlets and a rubber membrane in the middle - capacitor with two terminals.
A heavy paddlewheel in the the flow - coil (rotating mass is like inductance). How good it blocks (or accelerates) the flow is the Q factor.
A check-valve - electronic diode
So yes, they are similar.
Old 26th March 2012, 09:07 PM   #5
Andrew Eckhardt is offline Andrew Eckhardt  United States
It sounds like you know enough to make practical purchases and listen to them in order form your own opinion. Unfortunately in this sort of endeavor, unless you're looking for a lot of argument, that's ultimately all you get. I'll say that a good quality and well applied air core coil and film caps are going to sound different (usually better) than some type of iron core and electrolytics. Beyond that you'll have to determine what's best and why.
Old 26th March 2012, 11:13 PM   #6
5th element is offline 5th element  United Kingdom
5th element's Avatar
One thing to bear in mind is that the ear is very sensitive to small frequency response variations and especially so between 1-3kHz. As most crossovers to tweeters are placed in this region it is easy to see how a component change could cause the sound to change. Now one could of course assume this to perhaps be related to a better quality or different quality of crossover component, whereas in reality the components come with tolerances that are generally around +-10% to +-5%, not to mention differences in the series resistance.
If you want to do crossover component changes and be sure that you are really hearing the component you need to make sure that the frequency response of the loudspeaker before and after a component change are as close to being the same as is possible. Otherwise that difference in character could simply be a small change in output around the crossover frequency etc.
Generally speaking good quality electrolytics are fine, one can step up to a film cap and get appreciable performance increases that generally ends up meaning better component tolerances with respect to aging and a lower equivalent series resistance. Once you're using a decent quality film cap though (say a nice basic polyprop) paying for a supposedly better film cap is where the laws of diminishing returns really kicks in. Of course even basic poly caps can cost a lot when you're looking at large values of beyond 50uf. Here I tend to parallel a low size poly film cap with a large lytic. One area that can improve with price is the tolerance of the parts. I would much rather pay a small premium for +-1% parts of a standard cap line, then pay more for a supposedly better cap that was still at +-5%.
As to the question of the parallel connected 'shunt' cap in the 2nd order LW, low pass electrical network, the quality of the cap here can make an appreciable difference in the frequency response, but only if the ESR of the chosen cap is gross. The cap is obviously chosen with respect to the impedance of the driver and is 'tuned' one could say to a specific frequency. At low frequencies the caps impedance will appear as very high compared to the driver so all the signal will pass through the driver. As frequency increases the caps impedance begins to fall and you end up with some of the signal being divided between the driver and being returned to ground via the cap. If the caps own ESR is high it could start to dominate such that the response of the filter doesn't do quite what you're expecting it to do. Of course all of this can be modelled and factored into the design.
If you're altering an already bought loudspeaker then the only thing you can do is try it out. The good thing is that decent quality film caps aren't madly expensive unless you start using large values. As the loudspeaker is already using a lytic cap there is always the chance that it could have dried up a little and changed in value. If you can measure the caps and see that they are within spec, then it is up to you as to whether or not you spend the money. If they were in spec then I personally wouldn't change a thing.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 27th March 2012, 07:01 AM   #7
Thanks all for the metaphors and feedback. Having gone out to the local wine bar and then the local fried chicken and beer place since posting my original thoughts, I will need some time to fully process all the information (i.e., sober up).
re: hearing differences. I have a fairly mediocre short-term/working memory for most things, especially information (signal) presented auditorally. So unless I set the system up so that I can switch back and forth multiple times between two versions of a component within seconds, I don't expect that I will be able to detect which of two audio streams sounds "better" (I've tried this comparing different audio components - too much time switching between the different components to tell). I haven't even attempted to try a "blind" comparison. I'm mainly trying to increase my chances of producing the recorded signal with as much fidelity as possible.
@SonicR1 - I would have thought that across the vane and resistor there would be a pressure increase vs. a decrease. And for the tank/capacitor; the inlets are connected to each other outside of the tank (ie., the negative and positive poles of a circuit)? Do I have that right?
@DF46 And vice versa, right? Like a water tube level?
And what do you all think of the significance of the resistance differences between metalized film and aluminum.tin foil plates in capacitors? Electrolytic vs. metalized film vs. film and foil?
Cheers
Old 27th March 2012, 11:37 AM   #8
Well across the vane pressure decrease if you take refference the source pressure, in the direction of flow. This if you have a constant pressure source that feeds the vane.
If your water hose leaks back to ground, that atmospheric pressure would be "0 volts".
An electric power source is like a pump. It will convert a mechanical energy into pressure/flow, but the water that it "sends" away needs to return to the pump if you want the circuit to work continuously.
And yes the capacitor you got it right. Volume of chambers is the capacity. You can send pulsations back and forth via that membrane (AC), but no continuous flow (DC).
Old 27th March 2012, 12:43 PM   #9
On Hiatus
SY's Avatar
That's an important question. In some sopeakers, the designer is smart enough to make use of the higher ESR (equivalent series resistance) of an electrolytic cap as part of the crossover circuit. Substitution of a film cap will certainly change the sound, but may well make it less accurate than before. In other cases, the electrolytic will be used just because it's cheap, with no real design thought, and the film cap may or may not sound different or better.
Since decent film caps are cheap (avoid audiophile designer brands!) as are bipolar electrolytics, it's easy and educational to buy and try both and see which is the case for your particular speakers.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 27th March 2012, 01:21 PM   #10
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Where I found the biggest difference between electrolytics and film caps was in notch filters. The increased ESR of the electros reduced the effectiveness of the notch filter quite substantially. However a bit of esr can also be a good thing for damping resonances that might otherwise occur.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Where is the point of diminishing returns with caps in passive crossovers?Hide this!Advertise here!
What do you think of passive crossovers? Boscoe Multi-Way 333 20th February 2017 06:48 AM
Do bypass capacitors work on passive crossovers and what about shunt caps. . . erickalan77 Multi-Way 4 17th August 2011 05:52 AM
passive crossovers.... stuman Subwoofers 10 8th December 2009 03:44 AM
diminishing returns - what point ? vasyachkin Car Audio 11 22nd January 2008 10:48 PM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 10:16 PM
Copyright ©1999-2017 diyAudio
