I have a preamp circuit that will be connected to a class D amplifier. The class D amp has a input voltage up to 5v. I need to limit my preamp from going any higher than this 5v. What is the simplest way to accomplish this? Also, this is a single supply preamp and class d amp.
Thank you
Thank you
Back to back zener diodes.
This is a common practice with MOS-FET amps.
Either look at the http://www.passdiy.com or http://www.kk-pcb.com sites to see how it is done with very High End amps.
