| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Hi, long time lurker first time poster here so please be gentle. I have searched on this query and not found a great deal of info on balanced/unbalanced conversion inside a unit. Most posts focus on interconnection of different units. While I know the principles are the same the application is stumping me a little.
I am planning a control room monitor to switch 3 sets of inputs and 3 sets of outputs using relays with a passive attenuator between the input and output. The passive attenuator runs in a stereo balanced configuration. I also want to run 2 headphone outputs from the pre-attenuator signal. 1 of the inputs and one of the outputs is unbalanced Hopefully the image below explains things more clearly: ![]() I have assumed that I will need to convert the unbalanced signals to balanced and vice versa if I want to include unbalanced ins and outs on the units. As I am keen to use high quality components I am opting to use transformers for this purpose. The headphone Amps also take an unbalanced input so I have dedicated transformers to take the balanced input signal and converted it to unbalanced for the headphone amps. Questions: 1. Does this topology make sense - I appreciate it is expensive. Should I consider an alternative method to using transformers to convert between balanced and unbalanced that would still maintain signal quality? 2. Do I need to place a buffer between the input signal and the headphone amps or is it ok to route the signal to the attenuator and HPA's in parallel?I've been looking at a BUF634 for this. Is this required or recommended? 3. In terms of grounding I intend to ground all input and output shields to the chassis at the jack and signal grounds from PCBs using a star ground. Is this sensible/required? Is there an issue also connecting the unbalanced signal shields to this ground? Any other feedback would be most welcome. Thanks |
#3 | |
Converting the balanced ins to unbalanced and vice versa would cut down on components but the balanced signal would always be going through a conversion. I am less concerned with quality for the unbalanced ins/outs as these are for convenience. |
| Unbalanced to Balanced | mcash257 | Parts | 3 | 14th October 2004 12:03 AM |
| Balanced / unbalanced volume control, possibel ? | Rudy | Solid State | 4 | 28th February 2003 08:18 AM |
| unbalanced/balanced/unbalanced conversion using transformers | vladimir | Solid State | 10 | 27th February 2003 06:54 PM |
| unbalanced or balanced | theturtle | Everything Else | 4 | 5th January 2003 04:52 PM |
| Zen Balanced Line Stage Balanced vs Unbalanced | macka | Pass Labs | 28 | 11th December 2002 06:18 AM |
