Shielded Umbilical Question
Old 20th March 2012, 07:18 AM   #1
dbasford is offline dbasford
Default Shielded Umbilical Question
Hi, I am building a Hagerman Bugle and associated power supply. I am building them in a separate chassis and had a quick question about the shield on the umbilical. I am using a 4 pin XLR connector and it is wired as shown below
What I need to know is what to do with the umbilical shield. My best guess is to attach it to pin 1 along with the chassis ground wire on the power supply side only. The XLR connector also has a shell connection and I'm wondering if maybe I should ground it to that instead on the power supply side.
Thanks!
edit: forgot schematic oops!
Old 21st March 2012, 12:38 AM   #2
Speedskater is offline Speedskater  United States
Speedskater's Avatar
Connecting the shield from shell to shell might be the easiest.
Kevin
Old 21st March 2012, 01:12 AM   #3
pooge is offline pooge  United States
Your post is unclear about how many wires are in the cord, and what they carry. Do you have +/-/ground, V1/V2/ground, +/-/ground/shield, V1/V2/ground/shield?
Also, how you connect the output of the Bugle to the next stage, and what that next stage consists of, may be an issue, since the signal may eventually end up at a power amp with a supply ground connected to its chassis. You could end up with a ground loop from your Bugle all the way through to your power amp.
Old 21st March 2012, 01:30 AM   #4
Sorry, fairly new to this definitely forgot some info. The schematic for the bugle can be found here http://www.hagtech.com/pdf/bugle.pdf and the power supply here http://www.hagtech.com/pdf/powersupply.pdf. As you can see there is a +15VDC, -15VDC, power ground, and a chassis ground wire. Around these 4 wires is a shield and how to connect that is the issue.
I will be connecting to my power amp using RCA's, so it will be unbalanced. Amp is a Onkyo HT RC360, as this is my first diy project, a new amp will be in the works shortly after this is done.
Old 22nd March 2012, 03:53 PM   #5
Would that not create a ground loop as I have a wire already connecting both chassis together runnign through the umbilical?
Old 23rd March 2012, 07:32 PM   #6
The loop area is about zero. Ground loops are only a problem when the area between paths is large or current enters the loop at separated points.
Plus this way the chassis's and shields are connected to the shell and the safety ground/protective earth is connected to the pin 1's.
Kevin
Shielded Umbilical QuestionHide this!Advertise here!
Question about shielded wire... 6L6 Analog Line Level 4 5th January 2011 04:25 PM
Power Supply Umbilical Question SRMcGee Power Supplies 4 28th September 2007 04:43 PM
Neutrik XLR for Umbilical dsavitsk Tubes / Valves 14 17th August 2006 02:20 PM
Umbilical Supplies rtarbell Parts 1 9th March 2006 10:47 PM
Shielded or Not, that is the question. kilowattski Pass Labs 6 1st July 2004 04:20 AM
