| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Hello,
Could someone please advise at a balanced line signal level source what would the difference be between Attenuation Control & Gain Control? Also could someone please advise, if both options are possible which would the better of the two options as to preserving the integrity of the original signal. Any and all advise would be greatly appreciated! Thanks, jsa_ind |
#2 | |
take a look at L pad attenuation for balanced signals often called a U pad , the simplest way to do this is have equal value resistance for hot and cold leading into a variable resistance , now turn that U a quarter turn to the left to visualise. The connecting path between that lead in is a variable resistor usually of 20 thousand ohms or more. See; Uneeda Audio - Build your own attenuator pads The best way i know of preserving integrity is to use LDR's Light Dependant resistors which in this simple U pad implementation only needs 2 as the variable part for 1 channel of stereo. Silonex NSL32SR2 is recommended for its low on resistance. Cheers / Chris , |
#3 |
All active input circuits will impose a signal level limit, beyond which clipping or severe distortion will occur. If an input signal may be higher than this then it needs to be attenuated before reaching the active circuit. Too much attenuation will increase noise, so you need to have the right amount.
#4 | |
#5 |
Google for the Shure M267 schematic to get ideas how this could be done. E
| Transformer based voltage gain + unity gain stage? | soundcheck | Solid State | 2 | 10th August 2010 02:44 PM |
| Throwing away open loop gain with an opamp near or at unity gain | okapi | Pass Labs | 3 | 25th December 2009 01:23 PM |
| Heretical Unity Gain line stage PLUS a little gain ? | yagas | Tubes / Valves | 7 | 24th January 2006 01:30 PM |
| digital versus analog volume attenuation | frdchang | Chip Amps | 9 | 31st March 2005 04:46 PM |
| Unity Gain Operation (or low gain) | Tomo | Chip Amps | 12 | 22nd January 2004 01:47 AM |
