| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
I am looking to build a volume control for conductor monitor. I have a 10k log pot and am not quite sure how to wire it. Any schematics or ideas would be great.
Thanks! |
#2 |
Looking with the shaft at the front.
Left hand pin is ground in and out. Middle pin is audio out. Right hand pin is audio in.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software. |
#3 |
Thanks Nigel.
When I wire it with Pin2 going to Pot Pin 3 (input) and out of Pot Pin 2 (Middle, Output) I got hum and buzz unless the pot was at 100% I'm not sure why that was happening, I guess some sort of voltage imbalance. braxton |
#4 |
It will hum if there is nothing connected to it.
Does it still hum with something connected ? like a mp3 player.
#5 |
Yeah - I've got an mp3 player going into the pot. Here is the whole set up:
Input - Pin 1 -----Pin 1 on the Pot - jumped to XLR Pin 1 Pin 2 -----Pin 3 on the Pot Pin 3------Jumps straight to output XLR Pin 3 -Pin 2 on the pot out to Pin 2 on the output XLR does this make any sense? |
#6 |
#7 |
XLR pin 1 is a screen, not signal ground. Don't connect it to the pot, unless there is a separate ground tag on the pot's metal body.
#8 |
So am I essentially shorting XLR pins 2 & 3 via the potentiometer?
#9 |
Pins 2 and 3 on the input go to the two outer tags on the pot. Pins 2 and 3 on the output go to the left and middle tags. When the pot is fully anticlockwise (to the left) the input sees 10k, and the output sees a short circuit. At the other extreme 2->2 and 3->3 with a 10k across the line - full volume.
I'm sure that somewhere on the web someone explains how volume controls work. |
#10 |
Do you know what resistor value I would use when I short 2&3?
| Line-level Volume Control Possibilities | crosswick | Instruments and Amps | 1 | 27th February 2009 01:21 PM |
| passive line level volume control | CharlieM | Planars & Exotics | 1 | 9th March 2008 01:43 AM |
| volume level control | bob2000 | Everything Else | 3 | 17th September 2007 02:25 AM |
| lesser of two evils, high level -> line level, digital volume control | mazurek | Solid State | 3 | 19th November 2006 12:25 AM |
| Line level volume control | rs1026 | Chip Amps | 9 | 22nd May 2005 06:18 PM |
