Remotely Controlled Motorized Volume Pot.
Old 12th October 2012, 08:27 AM   #41
Dagwood is offline Dagwood  New Zealand
Dagwood's Avatar
Ok, had a rumage in the boxes of bits, now have a new set of transistors.
The mute function now works if pin 10 is shorted to 0v
Thanks for the offer of a code change but I dont have any spare buttons on the remote, only have Volume + & - and the mute. All other are used by the CD player
Cheers
If you keep digging in the garden of failure you will eventually find success
Old 12th October 2012, 08:29 AM   #42
fotios is offline fotios  Greece
fotios's Avatar
Originally Posted by Dagwood View Post
Could it be that I have used BC546 rather than MPSA06?
No, BC546 is OK. Simply Emiitter and Collector leads are inverse in MPSA06, check it please.
Best Regards FOTIS ANAGNOSTOU
Old 12th October 2012, 08:38 AM   #43
Dagwood's Avatar
Yes all is working fine, BC546, fitted inverse
Could pin 3 be triggered "On" with just a time delay of a few seconds rather than a pysical button push on the remote?
Old 12th October 2012, 08:57 AM   #44
fotios's Avatar
OK, that's fine .
Cheers
Now drop me a link to post you - within half an hour - a modified program code to solve your problem. Actually i will remove the "Inhibit MUTE" command if "STBY mode" exists.
Fotis
Old 12th October 2012, 09:19 AM   #45
Dagwood's Avatar
Thanks Fotis
Email sent
You are a star
Old 12th October 2012, 09:30 AM   #46
fotios's Avatar
If "pin 3" you mean the output for MUTE relay, it is automatically triggered - for a while - during power-up to prohibit audible thumbs from power supply.
OK, the modified HEX file is ready for you, i've programmed P16F88 with MPLAB ICD-2 to be sure that is working, and is working just fine on my test board.
Unfortunatelly i can't upload it on diyAudio forum because does'nt accepts HEX files. Also in Matrix Multimedia forum because my moderator duties, and this is a custom HEX file for you.
Fotis
Old 12th October 2012, 09:51 AM   #47
Dagwood's Avatar
Hi Fotis
Thank you so much for the revised code
It works perfect, will try to get it ftted to my per-amp tomorrow for final testing
Thanks again
Dagwood
Old 12th October 2012, 10:47 AM   #48
fotios's Avatar
Hi Fotis
Thanks again
Dagwood
My pleasure Dag
I feel happy to offer my help in other people, and more happy when my help is useful on actual projects.
Cheers
Fotis
Old 12th October 2012, 11:09 AM   #49
fotios's Avatar
Default Custom Remote Control Handset
For whichever is interested to build his own Remote Control Handset, here the link of a whole article:Matrix Multimedia user forums • View topic - Remote Control Handset "1"
It is implemented around a PIC16F1827, one of the recently launched micros of Microchip. This micro together with PIC16F1829 includes the new Data Signal Modulator (DSM) module, that is very useful for remote control handsets offering up to 32MHz carrier frequency. Its cost is some big at 7.5 Euro (you can buy from e-bay ready RC5 remote control handsets of Philips for just 6.5 Euro cluttered from tenths of useless buttons!) but is a DIY project .
Fotis
Old 13th October 2012, 02:06 AM   #50
Bob Richards is offline Bob Richards  United States
Bob Richards's Avatar
A year ago I would have been real interested in this remote volume control, and I appreciate the generosity of the code writer. In the last year I found that I can bluetooth 16 bit stereo digital wirelessly from my smartphone to my main stereo system in my living room. The Bluetooth receiver I bought for $20 from Parts Express in Ohio works pretty good, and only needs a 5 volt power supply or handy USB port to tap off of. I think that may be the future of front end sources, and my phone has volume, EQ and the mute function. The digital files don't have to be mp3. I have a bunch of mp3 which was given to me, as well as my own stuff that is all wav files without compression. Not super highend really, but pretty darn good. All my CD's are 16 bit... It's difficult to find the bluetooth recievers on the Parts Express website, but they are there. They don't tell you, but if you drive 32 ohm headphones directly with the bluetooth receivers (they say it can), they have a bunch of hash noise for some reason. Drive into 500 ohms or above and I didn't hear any noise at all. Feed it into an aux in on your preamp. Like most cheap Chinese stuff, the included instructions are very minimal.
Remotely Controlled Motorized Volume Pot.Hide this!Advertise here!
SIMPLE remote volume control with alps motorized pot ChopperCharles Tubes / Valves 23 3rd June 2016 03:13 PM
Slowing Adcom motorized volume pot bcmink Digital Source 1 17th January 2010 11:48 AM
Alps RK27112 10K Motorized Blue Velvet Volume Pot raghoser Parts 4 28th January 2008 02:24 PM
I need the infrared remote control schematic for motor controlled volume pot noyan Parts 4 24th July 2007 03:05 PM
FS: Remote volume control w/motorized pot theAnonymous1 Swap Meet 2 28th June 2006 11:38 PM
