Go Back   Home > Forums > Source & Line > Analog Line Level
Old 16th February 2012, 09:40 PM   #1
Default 3 TRS in, 3 TRS out, 1 knob volume.
I have a surround sound system on my computer that uses 3 x 3.5mm TRS cables (2 channels per cable). Unfortunately, the volume is entirely controlled within windows because there isn't a volume knob for the speakers.
What I'd like to do is create a volume knob that will evenly and transparently control all 3 inputs (6 channels total). An added bonus would be to have switches to disable each of the inputs individually (ie. if I just wanted to hear the L/R channel and not the Center/Sub).
Is this possible? If so, does anyone know how to accomplish this?
Old 20th February 2012, 07:45 PM   #2
Hi
I dont want to design it for you and theres probably a neater way of doing it but just to try and kick start this thread ......how about 6 potential dividers made of resistors and LDRs .The LDRs being driven by LEDs .The LEDs are fed from one variable voltage source . Brightness trimming on the LEDS would probably be necessary.
Old 20th February 2012, 07:47 PM   #3
Just use linear volume controls as in an equalizer. Makes it real simple.
Old 7th October 2012, 01:20 AM   #4
So, after getting discouraged back when I originally posted this, I'm back to wanting to make this. The problem is that I don't have any background in this at all, so I don't even know where to begin.
I'm assuming I need some kind of 6 ganged log potentiometer, but that's about as far as I've gotten. Is it as simple as just wiring to and from the pot, or are there other things that need to happen as well?
Using TRS Audio Jack Switch shivia Analog Line Level 1 7th August 2007 10:44 AM
matching trs in leach amp arthur Solid State 2 27th November 2005 12:56 PM
TRS to RCA cable turn_on_air Everything Else 1 25th July 2004 08:44 PM
XLR to 1/4" TRS? Kaiowas Tubes / Valves 4 12th June 2004 05:32 AM
Do not match TRS, buy matched! destroyer X Solid State 0 16th April 2004 05:20 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
