JC-80 eBay PCBs & Power Train
Old 15th June 2012, 06:36 PM   #161
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Wow!
Thanks John!!!
You da man!
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | USSA3 & 5 | FO v1.4 | TGM8 | VZ Audio NS OPS | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 15th June 2012, 06:41 PM   #162
pinnocchio's Avatar
John,
Would you mind someone making a PCB out of this schematics for DIY only or do you prefer not to?
Do
Old 15th June 2012, 07:30 PM   #163
john curl is offline john curl  United States
john curl's Avatar
These parts (Supertex) have not been made for years in T0-220 packages.
"Condemnation without Examination is Prejudice"
Old 17th June 2012, 03:22 PM   #164
Wolfsin is offline Wolfsin  United States
What gift to us all. Thank tou, John.
'gardz, Dick
Old 17th June 2012, 07:28 PM   #165
john curl's Avatar
Well, I hope the original schematics keep you guys on the right track. The JC-80 was a relatively successful design for its time (25-30 years ago), but the phono stage was soon superseded by the Vendetta designs. Big time people, looking for the 'best sound possible' like Dave Wilson and many audio reviewers, bought them. The 'core' of this design is still visible in many of today's highest quality preamps, including the Parasound JC-2 and the Constellation Audio series.
It is NOT important to 'slavishly' follow each and every circuit value or part in your own versions, but try not to deviate TOO MUCH from the ESSENCE of this design.
It is 4 quadrant symmetry, all fet, medium feedback, Class A, with reasonably high open loop bandwidth. It is NOT an OP AMP.
The power supplies can be modified (improved). I recommend a floating ground, rather than a CT ground. However you CAN add a air coil choke (think loudspeaker Xover choke) in series with the CT to keep the garbage from the CT into the preamp ground.
Shunt regulators are OK, as well. Good luck!
Old 7th July 2012, 03:17 PM   #166
undefinedza is offline undefinedza  Europe
Where does one obtain a kit to build this?
Does the JC-2 resemble the JC-80 in anyway? I've found this: Symmetric Complementary J-FET preamplifier JC-2 kit ! | eBay
Kind regards,
Chris
Old 8th July 2012, 11:04 AM   #167
Kind regards,
Chris
Nevermind, I've got my answer.
Old 20th May 2013, 09:59 PM   #168
jsimon is offline jsimon  United States
Thank you so much for the line amp schematics of the Dennesen JC-80 preamp. Could I also ask for the phono section as well. I know it would be very appreciated by all of us.
Thank you,
John
Old 21st May 2013, 12:01 AM   #169
john curl's Avatar
You DON'T want to build the phono. It is obsolete, and difficult to get the parts. Please try something else.
Old 21st May 2013, 02:01 PM   #170
I am just trying to repair my own Dennesen JC-80, the line stage section is working and is very, very good. The phono has no output and I suspect a bad FET, at least that's where the signal stops and the FETs have had their model numbers removed. It's a beautiful preamp even with it's "obsolete" phono section.
Thank you,
John
JC-80 eBay PCBs & Power TrainHide this!Advertise here!
JC-80 eBay PCBs Wolfsin Analog Line Level 406 15th March 2017 11:15 PM
MEMDIST POWER AMP + JC + TMC - help to set up padamiecki Solid State 8 10th January 2014 09:38 AM
Mod Cyrus II power train for PSX? enthusiastor Solid State 20 27th June 2007 03:35 PM
JC-3 class-a power amp millwood Solid State 20 9th January 2004 08:32 AM
