| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#91 |
He's in Los Angeles today and Montreal next weekend so no DIY for a while.
#92 |
The 33mH common mode choke arrived and I built the loading jig today. The jig provides a dummy load after the regulator (one 10 watt 150r resistor from each rail to ground). At 30vDC this allows 200ma to flow. Without load the voltage across the caps soars. Even with 1k bleeder resistors my caps reach 45v so hot plugging a loaded regulator might not be pretty.
The dropout for the Kubota is 4.9-5v. I have not yet assembled a tracking prereg but already know to expect a dropout >6vDC. While I want to keep as much dissipated heat as possible in the external enclosure, I also want to be able to swap regulators easily without altering the inductance. That means I want the loaded voltage at the output of the rectifier and caps board to be at least 30v + 6.5v (the dropout of the regulator with the larger dropout). Leaving a little extra will allow for error at a cost of a little more heat dissipation from the regulator in the same case as the preamp. |
#93 |
1 r-core 2x37vAC secondary
8 FFP20UP20DN Soft recovery rectifiers 2 thermistors 1 39mH CM choke your inductance TBD 6 2200ufd 50v 4 6800ufd 50v 2 1k 5w bleeder resistor 1 Dual Rail Linear Power Supply PCB 1 fuse 250ma Notes: 1) Regulator out voltage depends on regulator dropout; select transformer first then similate TBD's. if 30v secondaries, CM choke not possible 2) TBDs include choke inductance, capacitor voltage 3) pcb comes with add'l flex & written docs 4) fuse each channel separately 5) ebay advanced search 'by seller' audiosector for pcb and ssrecord for NOS talema common mode chokes |
#94 |
Is there any schematic available for the boards that are being sold on ebay? I have searched but have found nothing for either the original or the copy.
I would like to take a peek at the schematic, if just a partial.
"Some lures are designed to catch fish, others are designed to catch fisherman." |
#95 | |
'gardz, Dick |
#96 | |
I have schematics and boards for a couple of different versions of the Kubota regulator. I also have a couple of Borbely super shunts in use. It seems that regardless of what I monkey with they are the defacto reference for uses under 200ma. The JC-80 looks like a jfet complementary, differential to mosfet source follower with dc servo??? Hard to tell.
#97 |
Certainly there are complementary jfets, it is differential, the outputs are mosfets, and it employs servo circuitry. John Curl calls it a transconductance amplifier. There are two contributors who've completed and are listening and appreciating thier units but since neither has responded to your question I am doing my best.
'gardz, Dick |
#98 |
Just DIY!
For the schematics, it is another story... It is a John Curl IP and the only way you can get them is if you ask John or buy the PCBs from the Ebay resellers.
We all have the Chinese PCBs and schematics that are distributed with them but without author approval I do not feel comfortable handing them out... Hope you understand Thanks Do
PREAMPs : AMB α10 + JC-80 clone | Balanced DCB1 | AMPs: AMB β24 | Aleph 5 | Symef | Hiraga | ML-2 | Fetzilla | Telos 390 Clone DACs : TPA Buffalo II + NTD1 I/V | TPA OPUS + IVY III Speakers : Jim Holtz Statements | Astasia SD | Tubasson Mark 2 |
#99 |
Thanks Do. I think hags got what he needed from the schematic posted on the web but maybe not. I agree we should not divulge more than is already 'out there'.
The eBay cm choke vendor agreed to a matched pair of 39mH cm chokes and Wolfsin izAbout to test and measure incircuit, under load. I finished the long cut required along the edge of the main chassis mount. As soon as I invent a reliable banana holder I'll look for a peel to slip on! |
#100 |
Just DIY!
Here's the latest news from my friend's PSpice/Orcad simulation...
Setting the gain "If you reduce the value of R17, R18, R19 and R20 to 330 ohms, it will drop the gain to about 5.7x (15.2dB). This would cause the overall bias to increase somewhat, so you'll need to reduce the R41 trimpot adjustment a bit to get back to 230mA current draw." Using IRF610/IRF9610 "Running at the lower gain also increases the frequency response to -3dB at almost 15MHz. This is in part also due to the IRF610/9610's lower gate capacitance compared to IRF510/9510. Anyway, using the IRF610/9610 does not otherwise change the operating points or the gain of the amp." Asking if in simulation, IRF610/9610 was worse than IRF510/9510 "No, IRF610/9610 is not worse than IRF510/9510. It has lower gate capacitance so the bandwidth is wider. Reducing the gain also makes the bandwidth wider because an amp usually has a fairly constant gain-bandwidth product, that is, as you decrease the gain, the bandwidth naturally increases. Having a wide-band amp is good, 2MHz is superb, but 15MHz is not 7.5x better. We could only hear signals to 20KHz (ifthat much), but usually 10x to 100x that frequency is more than enough to ensure optimum performance within the audio band, such as minimum phase shift and distortion, etc. Too much bandwidth may make the amp act as a radio receiver in certain circumstances. Decreasing the gain should not degrade the sound. If anything, it should lower the noise floor significantly." The 2MHz was when running the simulation with 15.3x gain and IRF510/IRF9510... I will follow up with some graphs shortly! Thanks Do
| JC-80 eBay PCBs | Wolfsin | Analog Line Level | 392 | 4th April 2012 05:48 AM |
| MEMDIST POWER AMP + JC + TMC - help to set up | padamiecki | Solid State | 7 | 7th December 2011 12:34 PM |
| Mod Cyrus II power train for PSX? | enthusiastor | Solid State | 20 | 27th June 2007 03:35 PM |
| JC-3 class-a power amp | millwood | Solid State | 20 | 9th January 2004 08:32 AM |
