TL071 question
Hi. I'm trying to build a vu-meter with low-pass filter for line level signal, single power supply from 5 to 12 V and i need to set some kind of gain. In the attached schematic, when running some tests, OP1 was 1/4 LM324,everything works beautifully when replaced with TL071 all leds remain light up as there was no signal connected to the vumeter. What am i missing? TL071 can't work in single supply mode?
P2 does nothing. And C1 is wrong placed. I believe P2 is in between out and (-) input, and this way adjust gain. And C1 must be at the P1 to to block DC input. And if the case, there must be another C in the middle of P1 to input (+) and a voltage divider about VCC/2 to bias the (+) input.
Don't try to build variable gain.
If you use a variable pot in the feedback loop you are asking for noise and trouble.
Simply attenuate the input or the output and use a fixed gain amplifier.
Place the Low-Pass filter at the input and use a simple resistor chain to give you a balanced supply.
I just skimmed through all this...
The circuit in post #7 is OK but NOT for a single supply. It also needs "Vin" to be correctly biased.
For a VU meter noisy pots don't really matter do they ? If all you are doing is setting gain.
If running a single supply then the opamp has to be biased accordingly... that's easy, but is it going to do what you want ? The output will be at half supply. This all means the input and output has to be AC coupled unless it's incorporated into somthing that provides the appropriate bias and works with the output at midpoint.
Something like this. R1 and R2 must be equal in value and say around 100K
Rin sets the input impedance. Say 47K
Rf is a pot and sets the gain. Gain is Rf/Rin so make Rf 470K and you have a gain of 0 to 10.
The caps provide AC coupling. Say 10uF each.
Some opamps can't work with inputs right on a supply rail. Read the datasheet to find out.
One feature of the '324 is that the common-mode range includes the negative supply rail. (Maybe even a few mV below the negative rail.) The TL071 isn't guaranteed to work with common-mode voltages any closer than 4 volts from the rails.
At the very least, you need some variant of a 2-resistor "rail splitter" on the non-inverting input.
Dale
