Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th February 2012, 03:36 AM   #1
Default To build a high pass RL line level filter
Hello, I'd like to ask for help. I would like to remove my digital crossover and replace it with a RL HIGH PASS line level filter as an experiment.
Crossover freq is 335Hz, the amp input impedance is switchable, 600, 20K, 100K ohms (I am using 100K ohms). I am interested in a simple, 6db/octave filter slope.
Can you please tell me the values of R and L that I need? Or, if possible, how can I compute them on my own.
Thank you,
Herman
Old 13th February 2012, 02:03 PM   #2
Try the free Filterlab by Microchip and/or Filterpro by TI. E
Old 13th February 2012, 02:38 PM   #3
Why aren't you considering reducing the amplifiers
input coupling capacitor to do the same thing ?
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 14th February 2012, 12:18 AM   #4
mdynac is offline mdynac  United States
so how would i go about calculating a 150hz high pass filter for this input section?
Voyage MPD on Alix3/Objective DAC/DCB1 Mesmerize/AF4 xover
18" H-Frames
Old 14th February 2012, 02:56 AM   #5
I forgot to state that I am making a PASSIVE line level filter, not active. Using coupling capacitor, what would be the RC values that I need?
Old 14th February 2012, 03:01 AM   #6
I'd be guessing without working out whats going on there, and I don't
have the time to do that. If input impedance is 100Kohm then a 0.01uF
will give a 150Hz high pass in series with the input. But seeing that
coupling caps are a concern regarding quality it makes more sense
to change the internal coupling capacitor than add an external.
rgds, sreten.
And 0.0047uF, 4.7nF a 335Hz high pass for 100K ohm in.
(minimal) speaker level vs. line level high pass filter noviygera Analog Line Level 1 15th October 2011 09:43 AM
line level high pass filter rbrockman Analog Line Level 3 13th December 2008 05:21 AM
Line-Level Low-Pass Filter Design JustinAtGT Chip Amps 10 31st May 2006 08:48 AM
high-pass filter (low-level) keyser Parts 3 6th December 2004 03:02 PM
Passive line level low and high pass filter help Matttcattt Multi-Way 53 24th February 2004 04:16 PM
Copyright ©1999-2013 diyAudio
