If You Don't Have a SIT, Fake It... - Page 9 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th April 2012, 08:09 PM   #81
juma is offline juma  Germany
juma's Avatar
Originally Posted by tp147 View Post
... only, because I've such a DIY PS on stock...
Gott sei Dank that you don't have a loaded gun on the stock...
Old 14th April 2012, 07:19 AM   #82
tp147 is offline tp147  Germany
Oh,
I've some loaded guns arround here, but I didn't find a useful place for them in my Hifi gear yet
cheers
Thorsten
Old 29th April 2012, 12:05 AM   #83
wrenchone's Avatar
This is the latest version of the SIT preamp I've been trying out, with current source enhancement on the input buffer (and a sex change). Depletion mode MOSFETs are used lavishly throughout as current sources (relatively high current capability with high impedance, minimum parts count).
I tried using a 2SJ74 in the input buffer position, and was rewarded with some high frequency ringing in the step response, which also shows up in the gain-phase measurement. This is perhaps due to the relatively enormous input capacitance of the 2SJ74 (a little bird was whispering in my ear, "use the J175", but I didn't listen).
The attached schematic now shows the J175 (listen to the bird!), and I'll be evaluating that version soon. Both versions (2SJ74 and J175) fared very well in simulation, with about 1/2 the distortion of the original version of this preamp.
The 2.7 pF compensation capacitor shown in the schematic may be replaced with a "gimmick" for optimum response (fast but a trifle overdamped).
Old 1st May 2012, 03:13 AM   #84
wrenchone's Avatar
The little bird that occasionally whispers in my ear was right on, as substituting a J175 for the 2SJ74 at the input totally cleaned up the linear square wave response. It's now overdamped with no ringing (and a little slow, if you ask me). Check out the attached waveforms to see what I mean. The trace with the square sides is the input, and the one with the slightly sloped sides is the output. Right now I'm using a 2.7pF NPO disc for compensation, and it looks like a smaller cap would be more optimal. If I can find a regulation cap. I'll use that, otherwise, it's gimmick time...
When I get some spare time, I'll let the HP8903A analyzer take a look. My goal for this project is a circuit that reads at the analyzer residual level for both 1k and 10k input, at input levels that would result in 0.5-1V of output. It's a test of both the circuit and my setup.
Old 1st May 2012, 05:49 AM   #85
wrenchone's Avatar
Here's a magnified view of the response to really check out the switching edges - it's pretty symmetrical, so one edge will do...
Old 1st May 2012, 08:44 AM   #86
buzzforb's Avatar
Does the j175 have a counterpart. I have heard of j310/ j271, but this one is new snd still accessable.
...Shape the sound , Man!
Old 2nd May 2012, 02:43 AM   #87
wrenchone's Avatar
Siliconix used the same process for the J174-J177 series (chopper/switch) and the J270-J271 series (linear amp). The J175 and J271 have overlapping IDSS range - the J271 is selected for a narrower range of IDSS. If you have some (J271), it's a possible substitution. If you don't have them, good luck.. The J174-176 series is still available in surface mount and as NOS. I just bought 500 pieces of Fairchild J175 from Electronic Goldmine - they may still have some left. Cheap, too.
Old 2nd May 2012, 03:00 AM   #88
wrenchone's Avatar
One more thing - I selected the J175 for input duty because I have them (always a good reason, if you know how to use what you have), they have a low input capacitance (look it up and compare it to the 2SJ74 - if you are serious about building stuff you should be downloading these data sheets while they're still available!), and a reasonable transconductance (some data sheets will list this, even though it was a part slated for chopper duty).
The J271 was no doubt a selected version of J175 slated for linear amp duty. For a while, it was readily available from Mouser - no more. One other possibility would be the 2N5462, which you can probably still find on Ebay. The input capacitance is where it needs to be, but the transconductance is lower than the J175/J271. Any port in a storm...
Old 2nd May 2012, 09:06 AM   #89
buzzforb's Avatar
Thanks on both counts. I can get get the j271, but may get the 175 as well.
Old 6th September 2012, 12:47 PM   #90
treuben is offline treuben  Australia
Originally Posted by juma View Post
Hi Wrench,
here is my take on "turning a (MOS)FET into a SIT/triode". Fair Zin, low Zout, BW(-3dB)=1MHz, rail-to-rail swing (almost), high PSRR, Id about 15mA, sounds wonderfull - what more could a man want ?
Built, tested, measured (except for THD) - here is the schematics:
Does this one need any matching please Juma? Is it ok to build as is for a preamp (with a pot in front?
L'Amp: A simple SIT Amp ra7 Pass Labs 2749 Yesterday 02:58 PM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
SIT Power Amplifier??? mad_z Solid State 8 26th January 2009 08:31 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
Copyright 1999-2017 diyAudio
