If You Don't Have a SIT, Fake It... - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 20th February 2012, 06:59 AM   #21
wrenchone's Avatar
I just fired up my HP8903A for the first time with my breadboard shut away in a diecast bud box, and I'm getting results between .01-.05% distortion depending on frequency and amplitude. I find it somewhat suspicious that using a 1kHz center frequency, I get a really significant reduction in distortion when I engage the 80kHz high pass filter. This points to either pickup or oscillation. I probably need to change the input BNCs to ones isolated from the case, and use a single point ground. It would probably be productive as well to ground the box to one of the front panel ground connectors on the 8903A - which one? At any rate. I'll also be looking at my breadboard with a square wave input to try and smoke out any instability. Things are never really straightfoward....
Old 20th February 2012, 04:51 PM   #22
The one and only
Nelson Pass's Avatar
Usually it's pickup. If the circuit is oscillating you will see quite a bit of
distortion at audio frequencies. If you have a Gate stopper resistor it is
pretty unlikely the circuit will oscillate.
Old 20th February 2012, 11:54 PM   #23
wrenchone's Avatar
With the current setup, here's what I get for THD with the 80kHz LPF in place - 1kHz, 0.1V - 0.027%, 1kHz, 0.5V - 0.016% 1kHz, 1V 0.036%
10kHz, 0.1V - 0.03%, 10 kHz, 0.5V, 0.05%, 10 kHz, 1V - 0.154%
Gain is ~ 5.5, so the more realistic level of excitation is 0.1-0.2V.
Obviously, I need to put some more work in the setup. Another useful thing might be to cascode the depeletion mode mosfet current source I'm using for a load in order to cut down on its capacitance - this may improve the 10kHz distortion.
Old 21st February 2012, 01:26 AM   #24
wrenchone's Avatar
Here's the circuit I'm messing with for the time being.
Old 21st February 2012, 05:58 AM   #25
BFNY is offline BFNY  United States
Need to also tell us source output impedance (assumed to be 50 ohms) and load input impedance (assumed to be 1M ohm or greater for test gear). Try a load of 1k, 10k, 100k, and see what happens to your numbers.
Tweak the supply voltage , shown as +30V, up and down if possible, and see what happens. This may show a sweet spot. Simulation meets the real world.
Old 27th February 2012, 08:13 AM   #26
wrenchone's Avatar
The source impedance of the 8903A is 600ohms, with an input impedance of 100K. I won't tinker with these until I am sure of a proper setup. I modified my test box (it already had isolated in/out jacks) for a single point ground to the case, and connected that ground to one of the ground connectors on the 8903A front panel. The resulting measurements were made with 400 Hz LP and 80 kHz HP filters engaged:
1k/0.1V - 0.021%, 1k/0.2V - 0.012% 1k/0.3V - 0.011% 1k/0.4V - 0.0125% 1k/0.5V - 0.015%
10k/0.1V - 0.024%, 10k/0.2V - 0.022%, 10k/0.3V - 0.03%, 10k/0.4% - 0.039%,
10k/0.5V - 0.049%
Old 28th February 2012, 05:23 AM   #27
wrenchone's Avatar
Should have done this a while back. but here are the residuals read on the 8903A with a BNC cable hooked from in to out. I'm not all that impressed - maybe this beast needs a cal session, fresh caps, or a better cable (the ones I have feel dodgy). Anyway, with 400 Hz LP and 80 kHz HP engaged, the results are:
1kHz: 0.1V/0.0081% 0.2V/0.005% 0.3V/0.0047% 0.4V/0.0048% 0.5V/0.005%
10kHz: 0.1V/0.008% 0.2V/0.0047% 0.3V/0.0041% 0.4V/0.0043% 0.5V/0.0045%
Can some one else that also has an 8903A comment on these residuals?
Old 28th February 2012, 02:08 PM   #28
the spec on the 8903A in the range you are using is -80dB, or .01%
manual here - see page 1-13
http://www.ece.stevens-tech.edu/Boes...sersManual.pdf
also comments here
Differences between HP 8903A and HP 8903B
Looks like yours is OK. Maybe try an FFT method, like ARTA on a PC soundcard? That way you can see the harmonics.
Old 2nd March 2012, 04:01 AM   #29
wrenchone's Avatar
OK, so the 8903A is operating near (actually below) its published limits, and there's not a lot of difference between the 1kHz and 10kHz residuals (though the rise at low amplitude is a bit troubling). Anyway, it's established that the 10kHz THD is definitely higher than the 1kHz THD for the basic version of the "FETSchade" as shown.
The circuit depends on high levels of very local feedback for low THD, so that anything that impacts the open loop gain should affect the THD. There are two things that I can think of. The first is that any real current source load will have a finite impedance (albeit high) associated with a shunt capacitance. A single DN2540N5 has ~1M impedance (dependent on bias current?) with some associated shunt capacitance that will result in reduced open loop gain as a function of frequency. Also, the gain mosfet still has Miller capacitance, even though said capacitance is being driven with a source follower.
So, there are three approaches to reducing the 10kHz THD. The first would be to increase the gain mosfet transconductance by boosting the bias current, hoping that the impedance of the depletion mode current source load is not too adversely affected by the increased current. The second approach would be to cascode the current source load somehow. The third approach would be to cascode the gain mosfet. The fourth approach would be to accept the increased distortion and forge ahead.
Anyway, I finally got a chance to drag my test setup in to work and do a gain-phase plot on a HP 4194A gain-phase analyzer (if I ever hang out a shingle as a consultant, I want one). The frequency response is not shabby at all. The first attachment shows the G-P plot with markers at 1 kHz and 10 kHz.
Old 2nd March 2012, 04:04 AM   #30
wrenchone's Avatar
The plots shown here are the same damn scan with markers at 100kHz and the - 3dB point.
L'Amp: A simple SIT Amp ra7 Pass Labs 2623 5th January 2017 07:59 PM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 08:55 AM
SIT-Preamp VladimirK Solid State 36 27th August 2011 09:36 PM
SIT Power Amplifier??? mad_z Solid State 8 26th January 2009 09:31 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 11:46 AM
Copyright 1999-2017 diyAudio
