If You Don't Have a SIT, Fake It... If You Don't Have a SIT, Fake It... - Page 8 - diyAudio
Old 3rd April 2012, 04:16 PM   #71
Skorpio is offline Skorpio  Denmark
Originally Posted by juma View Post
Hi Wrench,
here is my take on "turning a (MOS)FET into a SIT/triode". Fair Zin, low Zout, BW(-3dB)=1MHz, rail-to-rail swing (almost), high PSRR, Id about 15mA, sounds wonderfull - what more could a man want ?
Built, tested, measured (except for THD) - here is the schematics:
I like this one
How would you evaluate it between all those fine circuits you and others have made in the past? I am thinking power follower driving duty...
Just to name a few:
-BoZ
-JBoZ
-B1 (sound character)
-Triode with CCS load
-Other relevant
Na, building will be done nomatter what within a few weeks
Old 4th April 2012, 06:01 AM   #72
wrenchone is offline wrenchone  United States
wrenchone's Avatar
I'll be starting another thread in the Pass Labs section called L'Fake, a response to the L'Amp featured there that uses the scarce Yamaha SITs. The mosfet/jfet combination I showed at the beginning of this thread is perfect for making a fake SIT with a largish mosfet like the IRFP140/240 or the IRFP044/044N, among others. I also have in mind some largish TO-247 Fairchild "house numbered" devices I got for a relative pittance from Electronic Goldmine. The nice thing is that this setup will work with just about any mosfet that's large enough to dissipate the required power. They just about all turn on substantially at 4V or so, so setting up the bias current and output centering is relatively straightforward.
Anyway, I've done sims with both resistive and current source loading - the current source load sims better in terms of THD. For someone that wants to mess around with a simple SE Class A amp using readily available parts, this could be the ticket. All sims I've done so far are dominated by 2nd harmonic, with the 3rd down 10-20 db, and the rest much lower.
Old 4th April 2012, 06:15 AM   #73
This one is promising!
I will be waiting
Old 4th April 2012, 06:43 AM   #74
wrenchone's Avatar
The Goldmine part turns out to be an HUF75329G, with much less gate capacitance than the other two devices I mentioned previously (~1000pF vs 1500 or more). It's rated for 55 V, so will be perfect for a Pass-ish single-ended amp. Goldmine is sold out of these devices, unfortunately, though those curious enough might be able to find the same thing elsewhere, or something similar or better in Fairchild's current lineup of devices.
I wouldn't obesess about it though, as just about any mosfet capable of dissipating the required power and voltage would work.
Old 4th April 2012, 08:57 AM   #75
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Wrench, lower device has to be enhancememt mode,correct. It would de nice to try LU or RO85 down low. Right now, i am thinking of 2sk2013 pre version. Love following the thread, btw.
...Shape the sound , Man!
Old 4th April 2012, 09:54 AM   #76
juma is offline juma  Germany
juma's Avatar
Originally Posted by Skorpio View Post
... power follower driving duty...
To drive a small PF (5-10W, 24V PS, see post #65) I'd use a Mu follower variant:
Old 12th April 2012, 07:41 AM   #77
If this fakes a SIT or a triode, I guess my ZEN4 is already a fake SIT amplifier?
And when I get around to upgrade it with the Semisouth FET, will it still be?
Old 12th April 2012, 11:10 AM   #78
tp147 is offline tp147  Germany
Hi Juma,
I'm just collecting parts to build your nice pre amp for my F3.
For tweaking my Naim gear I have a nice PSU which provides +/-15 V powered by two 15-0-15 V centertapped r core transformers. Regulation is alternatively ALW Superregs with AD797 or Teddy Pardo Regs.
While the Naim pre is also a SE amp, the symmetrical PS is a nice step forward.
I guess it would also be nice to drive your pre amp with a symmetrical PS. What has to be changed in your circuit and which regulation would you prefer?
thanks in advance
Thorsten
Old 13th April 2012, 12:54 PM   #79
juma's Avatar
thanks in advance
Thorsten
I don't see the advantage in using the symmetrical PSU. Circuit would lose its elegance, and coupling cap(s) would still be present.
It can be redesigned but it wouldn't be better...
The circuit has high PSRR and I didn't notice the improvement by changing the PS from LM317 to shunt reg...
Old 13th April 2012, 04:20 PM   #80
Thanks Juma,
only, because I've such a DIY PS on stock...
A little bit funny, but I'll build this little pre on small boards exactly as big as the Naim gain stages in my NAC 72 and I'll use it as a drop in replacement.
cheers
Thorsten
If You Don't Have a SIT, Fake It...Hide this!Advertise here!
L'Amp: A simple SIT Amp ra7 Pass Labs 2827 17th June 2017 10:48 PM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
SIT Power Amplifier??? mad_z Solid State 8 26th January 2009 08:31 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
Copyright ©1999-2017 diyAudio
