If You Don't Have a SIT, Fake It... If You Don't Have a SIT, Fake It... - Page 5 - diyAudio
Old 14th March 2012, 08:27 AM   #41
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
I put on a breadboard your first schematic as you can see on the pictures, to try it, as I need a pre with a little bit of gain.
I made it as per the attached schematic, with the following changes: R2 = 47K, R4=180K // 5pico silver mica (I also had some overshoot on my 10khz square, but now looks fine as you can see, also wanted to reduce gain a bit so I used an 180k), for R7 I used a trimmer in order bias the circuit (in my case around 510ohm), and for current source I used an IXYS IXTP01N100D set at 35mA.
For voltage regulation, a Salas BIB set at 30V and 210mA.
I used a 10k pot at the input.
Measurements on the scope were fine, with a bandwidth of 330kHz.
However, when I listen to it I got a quite high level of noise for my liking. Keep in mind that I use horn speakers which are more than 100dB sensitive. On less efficient speakers, this maybe tolerable, but not in my case.
Gain was still high for needs. As I understand, gain is determined by the ratio of R4/R2. Is it possible to reduce their values, without having to add a bigger cap at the input?
Despite that, I quite liked the sound initially, especially the bass was very good.
Any help on all these will be appreciated.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 15th March 2012, 04:39 AM   #42
wrenchone is offline wrenchone  United States
wrenchone's Avatar
If you used a pot to set the bias level and kept in in, this might account for the noise you mention. Even a nice Noble 50k volume pot will hiss like a nest of snakes with some DC across it (I know from sad experience). If the pot is still in place, try replacing it with a fixed resistor equal to the pot resistance at its current setting (just use a meter to measure) and you may be very pleasantly surprised. Since this is, after all, a line-level amplifier with low gain, I can't think of anything else that could account for audible levels of noise, even with sensitive speakers.
BTW, kudos to you for actually taking the initiative to build this circuit and listen to it. You actually beat me to listening tests. I'm still playing around with my distortion test setup so I can get realistic and consistent readings.
Old 15th March 2012, 06:17 AM   #43
vgeorge's Avatar
Yes, I still have the pot. I will replace tonight and report.
What do you think about the gain? Is it possible to reduce the ratio R4/R2, without having to add a bigger cap at the input?
Old 15th March 2012, 06:53 AM   #44
wrenchone's Avatar
What are you trying to do? The circuit is presently set up for a gain of 5 . If you want much less gain than that, why not use a follower? It's easier and less problematic.
Old 15th March 2012, 07:09 AM   #45
vgeorge's Avatar
Only that I would like a little bit less gain (3 to 4). I may try it as a follower also. Thanks.
Old 15th March 2012, 06:28 PM   #46
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Try this g=~3 with lower impedance in the inverting amp's Rf/Ri for lower hiss maybe?
Old 15th March 2012, 07:18 PM   #47
vgeorge's Avatar
Will try it.
Also, with the 117 I use at the input, I replaced the trim with a 330ohm resistor, instead of 680, in order to correct bias the circuit.
I only wonder what the influence of the electrolytic at the input to the sound. Will see.
Old 15th March 2012, 07:39 PM   #48
Salas's Avatar
Q1 170 was just what I had in the lib. You bias with your IDSS, and new R2,R3 ratio plays a role (R5,R4 in wrenchone's schema). So your 330 may get revised or not. See to have VR4/R4=<IDSS Q1 and ~16V before C2 to GND.
Old 16th March 2012, 02:56 AM   #49
wrenchone's Avatar
Salas, the whole point of this exercise was to be able to push up the impedance of the feedback network and yet have some drive available for the mosfet gate. The way you show it, you really need that electrolytic (or a great honkin' film cap), plus a buffer to drive the buffer.
Old 16th March 2012, 03:06 AM   #50
wrenchone's Avatar
One variation I'm thinking of trying is to replace the bottom resistor of the output voltage centering/gain network (R5, per the schematic in Post 41) with an active current sink. A low IDSS, low leakage electrometer fet like the PN4117 would be just the ticket as an active current sink for the few 10s of microamps that are needed to properly set the bias. Just a thought...
I'm currently working on a board that incorporates all the cascode enhancements shown in previous posts, plus an onboard shunt regulator. I'm curious to see how it will perform in my distortion test setup.It would be interesting as well to have it drive a simple buffer and a pair of headphones for a subjective evaluation. I may adopt this approach so I can avoid ripping up my living room setup every time I have a bright idea...
If You Don't Have a SIT, Fake It...Hide this!Advertise here!
L'Amp: A simple SIT Amp ra7 Pass Labs 2827 17th June 2017 10:48 PM
SIT Amp Article Out Now Variac Site Announcements 0 2nd December 2011 07:55 AM
SIT-Preamp VladimirK Solid State 36 27th August 2011 08:36 PM
SIT Power Amplifier??? mad_z Solid State 8 26th January 2009 08:31 PM
New SIT - old problem StevenOH Parts 2 13th June 2008 10:46 AM
Copyright ©1999-2017 diyAudio
