cs3318 and arduino - Page 8 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 26th March 2013, 12:56 AM   #71
glt is offline glt  United States
Originally Posted by maxw View Post
Yeah I've read that. I've used other I2C devices without issues but they were all 5V. This time I'm using one of these to change the level. Do I put the pull up resistors on the arduino to 5V or on the CS3318 side to 3.3V?
The board already has 10K pull ups. But you can use smaller pull ups if you wish. You need them on both sides.
Regarding your code:
Wire.beginTransmission(CSAddr); // Begin I2C
Wire.write(B10000000); // Chip Address and R/W bit
Wire.write(0x00); // select the register
Wire.write(0x99); // set register
Wire.endTransmission();
Wire.begin is for the chip address
Wire.write is to select the register address
The next write is for the value you want to write into the register
Wire.end sends the data and releases the bus
Try writing one register at a time.
www.hifiduino.wordpress.com
Old 26th March 2013, 11:49 PM   #72
maxw is offline maxw  United Kingdom
maxw's Avatar
Originally Posted by counter culture View Post
Is that ALL the code?
...because it won't do anything. Unless there's something about Arduino C that is radically different from all the C I've ever come across.
You need a main() routine, and you need to call those routines...
int main(void)
setup();
loop();
Otherwise show us all of the code, it's impossible to debug fragmentary code.
Yes, that is all the code. I don't think there is a main() routine in the Arduino IDE.
Thanks glt, this solved it. The first wire.write was not required. I put it in due to this being in the datasheet:
"The first byte sent to the CS3318 after a Start condition consists of a 7-bit chip address field and a R/W
bit", but I guess that part is taken care of in the Wire.beginTransmission.
Anyway, I got it going, then fried the chip. Not sure how but hey ho, learn as I go
Old 26th March 2013, 11:56 PM   #73
OK, thanks. I had a look at the Arduino programming language, I'll know in future.
Old 21st December 2016, 08:09 AM   #74
Hi guys.
After not manage to fix the PGA2310 clicks issue cause of the low resolution i searched the web and got to this post.
I saw in the first page that linuxworks used a pcb for the CS3318, i couldn't find anywhere to buy this pcb, is it available somewhere?
Isak.
Old 21st December 2016, 08:25 AM   #75
maxw's Avatar
You could also use a QFN adapter PCB but there is a reason the CS3318 didn't gain wide spread DIY use: it's a bit of a pain to work with.
Old 21st December 2016, 09:20 AM   #76
Thank you for your reply.
Can you please be more specific, what do you mean?
Is this chip is problematic in some way?
Old 21st December 2016, 09:49 AM   #77
maxw's Avatar
No real deal breakers but just a few things that make it a bit more tricky for DIY:
- It's expensive
- It's hard to solder (0.65mm pin pitch)
- 3.3V. Not a huge problem these days as there are more 3.3V device now but a couple years back options were more limited.
- Easy to destroy the IC. If one supply rail is connected but not the other it goes up in smoke. I think everyone who played with the CS3318 has fried at least one.
Old 21st December 2016, 10:02 AM   #78
jan.didden's Avatar
Originally Posted by isakeliyahu View Post
Hi guys.
Isak.
If you have the click issue with the PGA you will also have it with the CS. It is not caused by resolution but by having some DC offset on the signal. When switching the DC offset changes and that sounds as clicking. Because of the DC, the zero=volt switching of the PGA will not work.
Get rid of that and you get rid of the clicking.
Jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 21st December 2016, 10:07 AM   #79
Wow, lol
I got yaa, well hope for the best.
Did you manage to make a project using CS3318 arduino?
If yes, can you please verify that its clicks free?
Old 21st December 2016, 10:18 AM   #80
maxw's Avatar
The CS3318 was click free for me. So was the PGA2310. The PGA2310 issue for me was constant low audible noise.
Digital Volume Contol - CS3318 - MAX5440 Ridin '24'z Digital Source 5 8th June 2011 01:36 PM
Sylonex and Arduino preamp oenboek Analog Line Level 17 12th March 2011 12:50 AM
Arduino for audio projects? glt Parts 5 9th March 2011 05:28 PM
Cooling fans with Arduino seahuston Chip Amps 10 23rd October 2010 05:58 AM
Can DIY audio be like Arduino glt Everything Else 1 3rd April 2009 03:57 PM
Copyright 1999-2017 diyAudio
