Go Back   Home > Forums > Source & Line > Analog Line Level
Old 5th February 2012, 08:24 PM   #1
gruni is offline gruni  Germany
Default Three opamp 24db/oct crossover?
Hi everybody!
Is there any design that implements a full 24db/oct crossover in three opamps instead of four? Is it even possible?
The reason I'm searching for something like this is I want to squeeze the crossover plus an artificial ground into one quad opamp...
My first thought was to simply build a linkwitz sallen key low pass and sending the output with the signal input to a differential amplifier but of course that doesnt work (I think it is because of the phase shift caused by the low pass filter?)
hope you can help me!
Old 5th February 2012, 08:48 PM   #2
Boscoe is offline Boscoe  United Kingdom
It's done with two isn't it?
You could fit a high and low pass crossover into one quad op amp but I wouldn't want too...
I thought about it once, but then thought again.
Old 6th February 2012, 07:45 AM   #3
why wouldnt you want to?
yes thats the well known circuit used for 24db/oct crossovers.
I'm not searching for good sound quality. it must be small and cheap...
Old 6th February 2012, 11:06 AM   #4
Because I doubt you will able to find a great quad op amp but as your not going for the best sound quality then I guess your okay.
Old 6th February 2012, 11:32 AM   #5
godfrey is offline godfrey  South Africa
Does it have to be 4'th order then? I expect the capacitors will be more expensive than the opamps, and take up more space.
If you want to do everything with 4 opamps you could easily do a good 2'nd order crossover with one opamp each for: input buffer, low pass, high pass, and virtual earth.
Old 6th February 2012, 11:59 AM   #6
theAnonymous1's Avatar
LME49740 is a great quad. It's bi-polar input though, maybe jfet would be better (opa4134?).
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 6th February 2012, 03:39 PM   #7
You can do any order with just 2 opamps. Silly enough, you can do without opamps too, as long as your source output impedance and amplifier's input impedance are known and stay constant.
Make passive networks as you do with loudspeaker passive crossovers.
You can live without inductors - just use RC filter, and calculate the following stage as if it have input impedance of R+Rsource.
Gonna be messy.
3 opamps:
1. Input buffer
2. HP buffer
3. LP buffer
+ passive network in between.
You can go with 3rd order per single opamp in Sallen-Key way - 3rd order Sallen-Key Low-pass Filter Design Tool
Old 6th February 2012, 03:50 PM   #8
If its driving diy amplifiers you can move the last low pass section to in
the treble amplifiers feedback loop. Can't do that with the bass unless you
slug the bass amplifier for unity gain stability. You can though build a low
frequency lowpass around the bass amplifier as boost / subsonic filter.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 6th February 2012, 06:21 PM   #9
Gonna be messy.
Could you explain how this is done?
regards Andrew T.
Old 6th February 2012, 07:58 PM   #10
Looks troublesome for the mid section
Yet it got 12db slopes
24db LR crossover polarity digits Multi-Way 6 9th May 2011 12:18 PM
How can I apply a 24db/oct LR high and low pass filter to a WAV file? MikeHunt79 PC Based 12 21st May 2010 06:55 AM
Group Buy: Linkwitz-Riley 24db/oct xover PCB's substrate Group Buys 21 10th March 2005 11:44 PM
crossover slopes other than 6dB/oct multiples? MBK Multi-Way 17 7th May 2004 02:07 AM
Linkwitz-Riley 24dB/octave Phase Coherent Crossover djdan Solid State 30 25th September 2002 10:32 PM
Page generated in 0.12615 seconds (80.72% PHP - 19.28% MySQL) with 11 queries
