Go Back   Home > Forums > Source & Line > Analog Line Level
Old 6th February 2012, 08:41 PM   #11
Add a rail splitter and you can do it with quad opamp without getting into complications.
If my 15 V DC were the radius of the Earth, Mount Everest would be 1 meter tall.
Old 6th February 2012, 09:11 PM   #12
S3,
I don't need the answers I need the method to determine the answers.
Can you talk me through the 2pole High Pass shown?
C7, C8, R11, R17, R18.
How do you correct the component values for the non zero source impedance and the non infinity load impedance?
How do you arrange for the Q to come out at the desired value?
regards Andrew T.
Old 7th February 2012, 08:36 AM   #13
gruni is offline gruni  Germany
alright i think there is no real solution to this so i will just go with a dedicated rail splitter opamp and leave the quad opamp for crossover
Old 8th February 2012, 08:53 AM   #14
AndrewT, I've spent 2 evenings on the matter
First time i've managed to get the calculations work, but when i've dialed-in the 2nd stage, i always got -6db at filter's Fo. Filter's Q didn't vary much, something between 0.5 and 0.707, maybe 1.
Second time i calculated the transfer function for the circuit, simplified it to the
(s+1)/(s^2+s+1)
form, and then again i've got stuck
I tried to solve the equation for H=2, but got some unrealistic numbers.
I think it's the right time to google for help
24db LR crossover polarity digits Multi-Way 6 9th May 2011 12:18 PM
How can I apply a 24db/oct LR high and low pass filter to a WAV file? MikeHunt79 PC Based 12 21st May 2010 06:55 AM
Group Buy: Linkwitz-Riley 24db/oct xover PCB's substrate Group Buys 21 10th March 2005 11:44 PM
crossover slopes other than 6dB/oct multiples? MBK Multi-Way 17 7th May 2004 02:07 AM
Linkwitz-Riley 24dB/octave Phase Coherent Crossover djdan Solid State 30 25th September 2002 10:32 PM
Page generated in 0.06040 seconds (79.12% PHP - 20.88% MySQL) with 11 queries
