RJM Audio B-Board Project - Page 8 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 10th July 2012, 02:26 AM   #71
dimkasta's Avatar
Originally Posted by rjm View Post
While coupling capacitors might be more audible than other individual components, most preamp designs have several for good reason: they are extremely useful.
Thanks a lot for the answer Richard
Do you mind elaborating a bit? The reason I thought of the above was simplicity.
I really do not need all those switches. Only a 2 way source selector and a volume pot, both of which I am thinking of implementing with LDRs, so no clicking or scratching from them.
Something like that
When phono is on, R1 and R5 act as the attenuator, while R2 is ~30R.
At the same time R3 and R4 are ~50M while R6 is ~30R.
When CD is on, R4 and R6 act as the attenuator, while R3 is ~30R.
At the same timeR1 and R2 are ~50M while R5 is ~30R.
And on mute, all series resistors are ~50M, and Shunt ones ~30R.
Sorry for the longish post. I just really value your opinion
Old 10th July 2012, 05:58 PM   #72
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
Electrically speaking, that will work. Do you propose to have a physical input switch, and if so where is it positioned on the circuit above?
RJM Audio (phonoclone.com / G+)
Old 10th July 2012, 07:27 PM   #73
dimkasta's Avatar
No switches in the signal, only the LDRs. The rotary switch will control only the current in the LED side of the LDRs
Old 29th July 2012, 02:24 AM   #74
dimkasta's Avatar
ok after so much delay, I finally started buidling the preamp.
I will keep everything in a single box, so I am powering the b-boards from phonoclone.
Since I have not populated the z-reg parts, should I install the 100nF caps in C3 spot?
Board version is GZ 10e
Old 29th July 2012, 02:49 PM   #75
Richard Murdey
rjm's Avatar
Yes, the 100 nF ceramics are needed independent of what is powering the circuit, they ensure the stability of the transistors Q1-4.
Old 1st May 2015, 06:29 AM   #76
Richard Murdey
rjm's Avatar
Default B-board 3.0
In line with the last revision, the bboard will (hopefully) be updated to feature the improvements first developed for the Sapphire headphone amplifier.
Briefly, the changes pretty much copy the new Sapphire directly:
* active constant current sources replacing the emitter resistors
* Szilkai output
* BC337/BC327 transistors and 1/4W resistors
The parallel output transistors will be removed and the bias currents scaled down (optionally, they can be increased if you need to drive very low impedance loads). I'll include an input resistor this time... it makes it simpler.
My main concern is the layout and whether I can make the same compact board layout as before. One option is to remove the Z-reg section and feed the board from a regulated supply such as the V+/V- pads on the phonoclone board or an X-reg board.
Old 29th July 2016, 01:17 PM   #77
Richard Murdey
rjm's Avatar
Well that's embarrassing.
Coming back to this thread I find my latest version has a smaller revision number than the last version I posted here. Oops.
This is revision "2.1f1". It's a derivative of 3.0 above, I guess, actually simplified and downscaled a little with no loss in performance. The boards are just the buffer circuit with no regulation. You can power it however you like, with split supplies from 5 to 18 V. Current draw is ~<10 mA.
Old 3rd August 2016, 02:29 PM   #78
Richard Murdey
rjm's Avatar
Boards arrived this afternoon.
Black glossy finish and 2 oz copper layers gives these a swanky feel.
RJM Audio Sapphire Desktop Headphone Amplifier rjm Headphone Systems 1022 16th January 2017 07:57 AM
RJM 6DJ8 passive phono challenge! Pimp my board... rjm Analogue Source 6 24th June 2013 08:44 PM
RJM Audio Gainbloc Preamplifier Mk. I rjm Analog Line Level 11 8th September 2011 12:59 AM
Parts for RJM Audio/47 Labs Phoneclone jim rose Swap Meet 0 15th May 2011 07:55 PM
My First DIY Audio Project: A Custom CMoy Test Board. isen78 Chip Amps 9 9th March 2011 02:58 PM
Copyright 1999-2017 diyAudio
