RJM Audio B-Board Project - Page 5 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 15th May 2012, 01:20 AM   #41
kp93300 is offline kp93300  Malaysia
Originally Posted by rjm View Post
To check a few things, I'm building a second set with an experimental BOM, BOMX below.
  1. Emitter resistors R3,4 lowered to 1k to increase the bias current.
  2. Emitter resistors R7,8 lowered to 1R, which raises the bias current in the output stage to more closely match the driver stage, at the expense of stability and increased likelihood of thermal runaway.
  3. Ceramic bypass caps added in parallel to the four electrolytics after the Z-reg. If there is any high frequency stability issues, this should quiet things down.
Hi RJM
Any follow up in your experiment for items 1 and 2 when you lowered the resistor value?
What is the effect on the sound ?
thanks
kp93300
Old 15th May 2012, 02:20 AM   #42
Hi RJM
One more thing .
Have you compered the sound difference with buffer build with BC and BD transistor?
Which is more transparent ?
thanks again
kp93300
Old 15th May 2012, 02:50 AM   #43
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
@dimkasta
For the input resistor use whatever you have it's just a non-critical part, with no power draw.
@kp93300
Most of the changes came from the ceramic bypass caps. Changing the resistor values didn't make much difference, or at least not enough for me to get a handle on. All things considered, I should probably update the BOM values to the BOMX values. The extra current doesn't cost much from a design perspective.
I haven't played around with alternate transistors, of course just about anything can be used if you want to experiment...
RJM Audio (phonoclone.com / G+)
Old 18th May 2012, 12:29 AM   #44
Default questions from electronic illiterate
Hi Richard,
i am going to build this buffer with BD devices and compare to B1 from NP.
I am using it as a line level buffer after the LDR volume control and there is an output caps in the dac before the LDR
Hope you can clarify a few points for a electronic illiterate like me.
1)What is the current draw?
2)What is the dc voltage range usable for the buffer? My transformer is 18 0 and 18 0 ac.
3) If i use +/- 24 V dc before the Z reg, do i need a 1W zener in stead of 1/2 w ?
4) Will help it in lowering power supply noise by using LED for voltage regulation in place of zener?
5) Are the values of the cap critical?
6)How to match the transistor to get lowest dc offset ? What are the variables that determine the dc offset?
thanks for sharing your project
kp93300
Old 18th May 2012, 04:35 AM   #45
Richard Murdey
rjm's Avatar
That should be interesting. Just remember to have the ceramic bypass caps installed before you run off and start making comparisons.
Kit BOM runs at about 12 mA per channel.
Kit BOM has 25 V capacitors. That's your upper limit. 18 VAC secondaries will blow the caps, but if you are dead set and you are sourcing your own parts anyway the BOM can be changed to operate at considerably higher voltages. I can provide the modified BOM. Email me.
No, the Zener is running near its minimum current. Even with 24 V V++ the power dissipation does not increase significantly.
I can't imagine it would be worth the trouble. R12, C7 are very effective at filtering out the Zener noise.
No, not at all. You can move a factor of 2 either way.
I'm not sure as I haven't tried. I would assume matching hfe would do the trick. What you really want for low offset though is identical Vbe for a given static current and temperature.
Old 18th May 2012, 07:40 AM   #46
dimkasta's Avatar
In the buffered VSPS/Phonoclone scenario, if we ommit the Z-reg parts, where do we connect the common X-reg psu output? On the power pads on the buffer side?
Oh and have you noticed a difference connecting the buffer before (replacing R6/R8) and after the coupling cap (C3) ?
Dimitri
Old 18th May 2012, 10:24 AM   #47
Richard Murdey
rjm's Avatar
Haven't tried the latter, I've only had the B-board after the phonoclone C3.
For the former, and I admit I hadn't considered it before you asked, V+ and V- connect back to the B-board from the Phonoclone, but on the B-board neither the COM not the GND need be connected to anything. The common path is already made by the phonoclone's OUT-. In principle... I may be mistaken; you'll have to feel it out as you go along.
Old 18th May 2012, 11:39 AM   #48
dimkasta's Avatar
And where do we connect the V+ and V- on the b-boards? on the buffer side power pads?
Old 18th May 2012, 11:46 AM   #49
Richard Murdey
rjm's Avatar
Yes, the ones labelled +,-, as opposed to ++,--.
Old 22nd May 2012, 10:22 AM   #50
dimkasta's Avatar
About BOMX, any comments on the increased bias changes?
Have you decided to make this the standard bom?
I am asking because you mentioned some possible instabilities and thermal drifting.
RJM Audio Sapphire Desktop Headphone Amplifier rjm Headphone Systems 1218 22nd May 2017 02:52 AM
RJM 6DJ8 passive phono challenge! Pimp my board... rjm Analogue Source 6 24th June 2013 07:44 PM
RJM Audio Gainbloc Preamplifier Mk. I rjm Analog Line Level 11 7th September 2011 11:59 PM
Parts for RJM Audio/47 Labs Phoneclone jim rose Swap Meet 0 15th May 2011 06:55 PM
My First DIY Audio Project: A Custom CMoy Test Board. isen78 Chip Amps 9 9th March 2011 01:58 PM
Copyright 1999-2017 diyAudio
