Go Back   Home > Forums > Source & Line > Analog Line Level
Old 26th January 2012, 02:01 AM   #1
chaparK is offline chaparK  Australia
Default Resistor between line out and GND: what for?
Good day,
I was looking at a few output stage schematics and noticed on all a resistor between the line out and the ground, just before the output connector.
This resistor has always a large value, 10K or 100K, and is the last component of the output stage.
What's the purpose of that resistor?
Old 26th January 2012, 05:50 AM   #2
That resistor is there to provide a sure path for current to charge the output coupling capacitor to the operating D.C. bias voltage of the output stage during power up. The reason this resistor is typically large is because it provides a long RC time constant so that the output cap. doesn't charge too fast, and doesn't significantly load down or distort the amplifier output.
Ken
Old 26th January 2012, 07:26 AM   #3
Good day Ken,
Thanks many times for taking the time to explain and for sharing your knowledge, it makes now perfect sense .
Cheers
Nick
finding feedback line and gain controlling resistor guitar89 Solid State 13 4th August 2011 10:53 PM
SMPS Gnd, Chassis-Gnd, and Layer Stack gearheadgene Power Supplies 1 5th July 2011 12:00 PM
Eliminating series resistor at line output? Omega_Void Analog Line Level 11 13th November 2010 01:11 PM
Why do you need a grid to ground resistor on a line stage? phrarod Tubes / Valves 7 7th May 2010 02:35 AM
Using resistor in sense line to increase range of regulated supplY? VictoriaGuy Power Supplies 3 12th December 2008 07:54 PM
Page generated in 0.06118 seconds (75.24% PHP - 24.76% MySQL) with 10 queries
