| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#11 |
Ultimately measure between output and ground of each channel.
But 1.5mV is as close to zero as most designs get. It seems that the two amps have survived the solder blob. |
#12 |
#13 |
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
OK, my friend, if I can help you, better. Beware IŽll go vacations this friday, so IŽll be away from computer during this following 2 weeks. Aleluya!!!
A veces pongo un circo y me crecen los enanos... "Que se llama soledad", Joaquin Sabina, el capo. |
#14 | |
#15 |
If you want to be really safe. Buy yourself a pair of cheepie RCA interconnects and put a 1uF cap in series with the I/P.
For a couple of dollars you might protect against catastrophic damage. |
#16 |
OK, no, I will use my free time to make some bricklaying in my own house and change the all day job.
A veces pongo un circo y me crecen los enanos... "Que se llama soledad", Joaquin Sabina, el capo. Last edited by Osvaldo de Banfield; 25th January 2012 at 04:26 PM. Reason: typo |
#17 |
Sorry, I couldnŽt understand you... 1”F, where? , for what?
#18 | |
or what is the purpose exactly? |
#19 |
Citation 17? Check the resistors on the output to the amp selector at the very left back (port for the plug for amp/speakers). There are resistors tied to ground there, one may be burnt and I mean toasted to no longer making any connection as in fired up. No testing needed just verify they are not blown (apart).
If all is well and your voltages check to what they should be (your 2nd time around test indicated so) I would plug in and put on some music (try some test speakers first). Maybe your DIM is flakey, due to not fresh batteries giving you hokey measurement the first time around. If it was me... I'd get a fresh set of batteries in DIM and give a 3rd test, results same and 2nd test, then hook it up and play (again test speakers) and turn it up and enjoy. Cheers, Bob |
#20 |
I got my DMI from China for $10 shipped
![]() I tested everything again tonight in the Citation 17 and it was all good. All Voltages normal, zero DC at the terminals and low and behold it played without a hitch. Still sounds great. I certainly can't explain what happened with he first set of readings but I am happy to have learned how to test the preamp. I think I am going to replace the resistors next to MF Thanks for your help guys!
| High Voltage Soldering (IPC Standards?) | kenpeter | Tubes / Valves | 3 | 13th November 2008 10:26 PM |
| tube voltage regulator error amp | nhuwar | Tubes / Valves | 14 | 20th May 2008 10:38 PM |
| Weird Voltage readings after rectifying | superR | Chip Amps | 13 | 28th November 2006 09:36 PM |
| Voltage readings on Bal Line stage Main Board | Zapped | Pass Labs | 6 | 25th July 2005 06:42 PM |
| Error in LM3886.pdf re: voltage drop? | officeboy | Chip Amps | 6 | 27th May 2004 08:15 PM |
| Page generated in 0.11091 seconds (78.17% PHP - 21.83% MySQL) with 11 queries |
