Go Back   Home > Forums > Source & Line > Analog Line Level
Old 23rd January 2012, 11:08 PM   #1
Ecaroh is offline Ecaroh  United States
Default Selector switch - replacement - shielded wire?
I'm replacing the selector switch on my Arcam Delta 290 integrated. Failures of this remote-controlled Alps switch are well documented on the Web.
Pretty straightforward, I have a nice small Grayhill switch that will fit. Wires will travel two inches or less for one channel, an extra inch for the other channel, crossing over those for the first one. Connecting into the pinouts for the old, board-mounted switch.
I’ve seen plenty of selector-switch wiring without shielding but have seen various recommendations to the contrary for build-your-own preamps.
Option A: no shielding
Option B: I have some shielded, six-lead wire, and I could use a length of this for each channel's inputs, running the board end of the shield to a convenient ground, and using another length of shielded for the switch's out. This could help isolate the channels from each other.
Option C: Run separate shielded wires, or twisted pair, for each input, and run all shields to ground at board end. Pretty cumbersome, with 14 shields requiring connection to ground. But this would isolate all sources from each other.
So it seems like it's Option A or Option B. What do knowledgeable people suggest? Thanks.
Old 24th January 2012, 09:49 AM   #2
DF96 is online now DF96  England
You might get away with a couple of inches unshielded, provided you are inside a grounded metal case and nowhere near any internal power wiring. Don't do option B, as that might give you crosstalk between inputs.
You could try some unshielded, using your source with the highest output impedance (as this is where any trouble is likely to be worst). If OK, then do the rest.
Old 24th January 2012, 11:15 AM   #3
Does the selector switch only the Hot signal connection, or does it switch both the Hot and Return signal connection?
regards Andrew T.
Old 24th January 2012, 05:07 PM   #4
The old switch, and the board, only do the hot (diagram attached - SW202).
Thanks for replies so far.
Question about shielded wire... 6L6 Analog Line Level 4 5th January 2011 04:25 PM
shielded wire dosilegecko Tubes / Valves 8 30th March 2010 07:57 PM
Shielded wire fsjonsey Tubes / Valves 7 21st March 2008 03:33 PM
what source selector rotary switch and how to wire it bemoth Parts 29 1st February 2008 01:31 PM
Page generated in 0.07757 seconds (69.93% PHP - 30.07% MySQL) with 11 queries
