Go Back   Home > Forums > Source & Line > Analog Line Level
Old 22nd January 2012, 04:38 AM   #1
Default Which opamp in this preamp circuit?
I recently dusted off this ebay-bought pcb I had sitting in a cupboard for a year or so. Whilst I do have the schematic (see pic below) and recall that the circuit uses 2SK170 and 2SJ74, I don't recall what opamp it was designed for. Is anyone able to assist?
Old 22nd January 2012, 09:54 AM   #2
Is it a single or a dual?
It needs to be unity gain stable.
regards Andrew T.
Old 22nd January 2012, 10:28 AM   #3
KatieandDad's Avatar
If in doubt build it with an IC socket.
Then you can swap Op-Amps without compromising the PCB tracks.
Use a nice gold-plated turned socket - they're not expensive.
Old 22nd January 2012, 11:36 AM   #4
I would use an AD825.
Old 22nd January 2012, 11:37 AM   #5
Definitely single - there is one socket per channel
How did you determine it needs to be unity gain stable?
What is a good starting point for a unity gain stable DIP single channel opamp, which runs at +/-15v?
Old 23rd January 2012, 07:14 AM   #6
lydlaug is offline lydlaug  Norway
Hi
It seems to be the same schematic as on this one
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
And they stated to use OPA627.
TL071 opamp circuit needed space2000 Solid State 19 23rd May 2008 06:20 AM
Can anyone help with this opamp circuit? lt cdr data Solid State 4 20th May 2005 10:12 AM
Transistor/opamp circuit soundNERD Chip Amps 12 15th September 2004 02:16 AM
Need Opamp Mic Preamp Circuit JojoD818 Solid State 15 2nd August 2003 04:15 AM
Page generated in 0.09365 seconds (76.83% PHP - 23.17% MySQL) with 11 queries
