| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Based on the VH Audio's design, I made a pair of the OCC 5N 28 awg solid core silver cables last week. The results are amazing: open sound stage, airy, focused images and very detailed. I can hear more weak music tones and can now define the "distance between layers of music".
They beat my 3 other diy solid core silver rca cables. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() What I'm going to do next? I'll re-do those cables which were twisted conductors in design
#2 |
I wonder if the added inductance provides a more effective vhf filter?
regards Andrew T. |
#3 |
Hi Andrew,
Could you please explain a little bit more about effective vhf filter? Thanks. |
#4 |
what happens when the humidity changes?
water is highly polar, relative pemtivitivy ~ 80 even polystyrene dielectic loss increases ~10x with its miniscule <0.1% equilibrium water absorbtion quick search finds: "Cotton can absorb about 25 times its weight in water" although only the 1st 5-6 % of water molecules by wt % are bound directly to the cellulose free hydroxyl groups Last edited by jcx; 22nd January 2012 at 12:55 AM. |
#5 |
inductance of cable pair = L
Capacitance at the receiver = C 2pole passive filter = LC
regards Andrew T. |
#6 |
What about no shielding?
#7 |
Audiophiles will argue for years about what interconnects to use.
I use decent Nakamichi Gold RCA connectors with RG58 Satellite Co-Ax and the sound is wonderfully transparent, clear, and with a good sound stage. I eventually sold my pair of Chord Chorus interconnects because the RCA connectors weren't maintaining a good connection with the RCA sockets on my equipment. The satellite RG58 cable is double shielded and good for 600MHz it does a brilliant job at Audio Frequencies. I'm sure loads of you will disagree. |
#8 |
I just worry that the construction shown is niether shielded or twisted pairs, basicly they form a dipole structure, not very good in areas of high rf pollution, ie any city town etc.
I had a reel of RG58 used it for everything, as I had 100m of the stuff, also used F connectors for it as I still have hundreds of the things...great all rounder. Last edited by marce; 22nd January 2012 at 09:22 AM. |
#9 |
just use ribbons folks they're plain better ![]() Some 3 mm x 0,05 mm silver foils are good for interconnects. For speaker cable, use 30mm x 0,05 silver or 0,07 copper to maintain a good cross section, with no thickness at all. Commonly found in ribbons chokes. Esay source of material for the diyer. Ribbons will have to be tight wound in order not to vibrate. Use pfte strip aznd an assistant to do this ![]() Don't forget low metal mass connectors, silver lead free soldered At least Allen Wright showed us the way ![]() Best, nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ![]() "Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright
#10 | |
What are these and where are they to be found? Brgds
These are my principles, and if you don't like them... well, I have others. |
| Cotton-insulated silver wire | Steve Eddy | Everything Else | 115 | 9th June 2011 11:00 PM |
| Silver interconnect | tubee | Parts | 0 | 13th January 2009 08:25 PM |
| UniCrystal OCC silver wire/cotton | Biscuits | Parts | 0 | 4th June 2008 09:52 AM |
| ssabripo's DIY Interconnect cables: $200 cables for 1/10 th the cost! | ssabripo | Everything Else | 3 | 26th October 2006 02:33 PM |
| Silver Interconnect | mike m | Parts | 1 | 16th January 2003 11:12 PM |
| Page generated in 0.12524 seconds (82.63% PHP - 17.37% MySQL) with 10 queries |
