| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Audio Junkie
I picked up a Krell KAV-250cd output stage board (non MKII) and spent some time drawing out the schematic. fairly unimpressive actually. I did not drawn out the D/A and I/V stages as i was more interested if the board could be used as a line amp.
They are using an OPA2604 opamp to convert from singled ended to balanced drive to a set of bipolar output sections comprised of MPS8099 and MPS8598 transistors. These boards are dated 09-98 so it's an old design now but it was interested to get a glimpse inside the design... Zc
It's not about what you can BUY...It's about what you can BUILD! |
#2 |
yeah, I don't see the point in the bipolar output stage.
My Website: Hyperacusis, Tinnitus, My Story |
#3 |
Audio Junkie
its an emitter follower stage that provides current to drive long cables. Now whats interesting is the MKII version board is MUCH bigger with many many more transistors. Now whats not show in this schematic is that there are 2 more opamps that are before this stage and after the PCM1702D/A converters. I have not drawn out that part of the circuit yet. it looks to be either a I/V stage or maybe a filter. the board was also supposed to have a PMD HDCD chip but that is long gone too. Im curious if the MKII board they did all discrete instead of opamps.
#4 |
Somewhere in the back issues of "The Audio Critic" David Rich comments on the somewhat unusual Krell designs.
The Audio Critic
Kevin |
#5 | |
Also it has changed transport (now it consists Daisy short loader mk2, based on Phillips CDM 12.01) The only op amp on that board is 0P97 but it seems to have some servo role - difficult to say wthout schematics
eddie |
#6 | |
So, it just seems like a bad idea to me, but perhaps there is something I'm missing.
#7 |
Audio Junkie
I stripped the DAC chips and opamp filters off the board and turned it into a Buffer with Unbalanced input to Balanced (or unbalanced) output. I calculate 12db of gain. 500mv input gets you 2v out across the balanced output. Might make an interesting low budget line stage section. going to have to listen to it and see how it sounds.
| Take a picture of your Krell KAV-300i please? | egeriis | Solid State | 7 | 24th January 2012 07:55 AM |
| KRELL KAV 300I Schematic Anyone ? | vdavidov | Solid State | 10 | 5th December 2011 02:15 PM |
| Krell KAV 250a deader than a dodo | digitallake | Solid State | 68 | 30th January 2011 08:55 AM |
| Krell KAV-250CD mk2 | eradoncic | Digital Source | 8 | 21st September 2010 04:58 AM |
| Krell's discrete I/U (I/V) converter for PCM1702 (Model KAV-250CD) - Schematic wanted | tiefbassuebertr | Digital Line Level | 23 | 22nd June 2010 11:49 AM |
