| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Here's the link:
http://www.extremecircuits.net/2009/...sed-on-fet.htm Here's my problem: I'm trying to find a 0.1uF 25v capacitor, but all I can find is 50v ones. Is it ok for me to use a 0.1uF 50v capacitor instead of the 25v one? I read somewhere on the net that it is best to use the capacitor that is closest to the amount of power coming in (+9v). I did find some 25v capacitors, but they were Surface mount. I really don't have experience with surface mount capacitors and I am not even comfortable trying to solder them. I'd rather the capacitors that have legs on them. Any help? |
#3 |
I uploaded an image of it... check it out.
You sure 0.1uF 50v caps would work as a substitute for 0.1uF 25v caps? |
#4 |
Completely over engineered, just use 2 resistors to mix them two channels.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#5 |
Without knowing the purpose of this circuit it's hard to comment much, but I'd have to be really armtwisted to use any input capacitors at all (or even any active circuitry at all, as nigelwright7557 says). If they were necessary because of possible DC voltages appearing at the inputs, I'd want much higher voltage non-polarized caps and some kind of overvoltage clamps, maybe zeners. What kind of guitars is this to be used for?
All good fortune, Chris |
#6 |
I wasn't actually planning on using it for guitars..... I just needed a stereo to mono circuit to convert a stereo line to mono.
The reason I picked this specific schematic is because it is possible to add as much "channels" as you want. If that were not the case, I would have simply just wired both audio signals to create a mono signal and call it a day. |
#8 |
0.1uF sounds a bit low depending on the value of the pots. The effect of the cap is to roll the bass off because it forms a high pass filter.
Have a read at this, High-pass filter - Wikipedia, the free encyclopedia Same goes for C3, as the load impedance you hang on the end of this circuit also forms a filter. I would use small 4.7 uF electroylitics all round I think (watch the polarity), and it would be good practice to add a resistor to ground across each input and also across the output to "charge" the caps at switch on.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
| Stereo and Mono from Stereo source | MegatronUK | Parts | 5 | 3rd February 2012 07:53 PM |
| Keyboard output circuit - stereo/mono | f69tele | Instruments and Amps | 12 | 16th September 2011 05:44 PM |
| stereo to mono network/circuit | wesley530 | Car Audio | 2 | 5th December 2007 11:52 PM |
| Mono DAC using sample/hold circuit for stereo | mr_push_pull | Digital Source | 0 | 29th September 2006 07:35 PM |
| wanted quickly!!!! a circuit to convert mono to stereo. | sagarverma | Analog Line Level | 4 | 10th May 2006 11:06 AM |
| Page generated in 0.08486 seconds (79.49% PHP - 20.51% MySQL) with 11 queries |
