| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#11 | |
![]() I also use his polyprop caps, they're not bad, if I have no room for PIO or teflon. |
#12 |
Somebody is kidding us on.
First we get linked to soldered RCA plugs. Then we get linked to solderless RCA plugs that were >$26 and subsequently discontinued.
regards Andrew T. |
#13 | |
If you mean the earlier links, I can't see which ones are discontinued, but I can see some expensive ones.
#14 |
Having received the Valabs I just wanted to say these connectors are GREAT!!!
One more question if I may... Are there cheaper alternatives to the Valab? I still need solderless RCA plugs, but not as expensive as these...
My F5 is being constructed as we write... |
#15 |
Yes, there are cheaper plugs, but I have found that the screws strip their threads on some cheap plugs. You get what you pay for - if you are lucky! You could try these- Audio Catalog I mean these - RCA-M02GS; remember you need 3 screws.
I have used him also, just ask for final price, including postage. Last edited by awkwardbydesign; 3rd February 2012 at 07:37 AM. Reason: adding detail |
#16 |
Thank you!!!
#17 |
What is the issue with using solder rca plugs? Is it just that you don't want to solder, or is the screw connection better?
Mark |
#18 |
For various reasons I don't want to solder at home. One of them is that 3 babies are present in a pretty confined space...
#19 |
| DIY RCA Interconnects | Tripmaster | Everything Else | 1 | 15th July 2010 09:36 AM |
| WTB: 1 m well made high end interconnects rca rca pair thanks | spwal | Swap Meet | 1 | 18th February 2007 02:31 PM |
| DIY Eichman bullet RCA plugs | tom1356 | Everything Else | 17 | 21st March 2003 05:24 AM |
| Page generated in 0.10453 seconds (78.23% PHP - 21.77% MySQL) with 10 queries |
