Go Back   Home > Forums > Source & Line > Analog Line Level
Old 12th January 2012, 04:54 PM   #1
hozone is offline hozone  Italy
Default active tri line splitter using BJT transistor
hello,
i'm building an active line splitter based on BJT transistor
i need to split the line output signal of my tascam us122.
( specs of the card:
Nominal output level : –10 dB
Maximum output levels : +6 dBV )
i will use this splitter to send signal to
* speaker amp 1
* speaker amp 2
* headphone amp
for my audio recording studio
- question 1 -
how can i transform the output db/dbV value to voltage?
i've already build a line splitter, based upon
* AMZ - Guitar Effects & JFET Splitter
* Basic Buffers
schematics attached (VCC is +9v)
i've checked this with a scope and a sine signal sweep (0.3V - from 10Hz to 25Kz), it seams to me that the FFT is 1:1 to the original sine signal.
- question 2 -
is this FFT check right?, i mean, is it right to check the frequency response by looking at the generate FFT during a sine sweep?
- question 3 -
i've also check that the output sine is the same amplitude that the input one, for the sweep, and it seams so. is it a good test?
- question 4 -
there are errors in my schematics?
- question 5 -
there is any opamp good schematics for this?
thank you...
Old 13th January 2012, 10:38 AM   #2
Mooly's Avatar
Your circuit is fine although unusual.
R1 could be usefully lower in value.
C1 could be larger depending on the LF response you want.
C2,3 and 4 could likewise be a little larger if you want extended LF response.
Thats all a matter of personal choice.
Using 3 followers is unusual. Remember the bias network has to supply 3 lots of Ib so you want high gain transistors to minimise loading.
It's all very workable but unusual.
Do you need 3 followers ? One opamp output would easily drive 3 outputs, or you could use a quad opamp and use one as a buffer and have the other three as followers.
Even a soundcard output should drive 3 inputs OK.
If you only have a single rail supply avalable the transistor option is absolutely fine.
Even 1 follower would drive 3 inputs.
You could also replace the emitter load resistors with constant current sources.
A follower like this will be good up to many hundreds of Khz when loaded lightly.
Sine wave test is fine, it will also be essentially perfect on squarewave testing too.
For db's and db/v you will have to do some reading and maths...
this covers what you are asking but you need to know impedances and levels,
Decibel - Wikipedia, the free encyclopedia
A simulation free zone. Design it, build it, test it.
Old 13th January 2012, 03:55 PM   #3
thanks,
R1 => 1M, ok?
C1,2,3,4 => i would like an almost perfect freq response, even on LF, from 50Hz to 25Khz, better C1 => 0.3uF - C2,3,4 => 10uF?
dbu, tks i've found the solution with some math.
i can use dual supply, or make a virtual ground circuit, so i can also use an opamp for this project. do you know any good schematics?
Old 13th January 2012, 04:05 PM   #4
Mooly's Avatar
If you want an opamp it's text book stuff. You must use "unity gain stable" opamps such as OPA2134 (which are duals so you need two IC's). FET opamps also produce zero DC offset.
If you're stuck I can draw a simple schematic later but it's all text book stuff. All stages are connected as followers with the three (if that's what you really want) separate driver stages all fed directly from the first stage. Good practice to isolate each final output via a small resistor of say 68 ohms to ensure total stability with long or capacitive leads.
Old 13th January 2012, 04:06 PM   #5
Why use circuitry at all ? -10dB is 300mV - typical home audio line level.
Most line outputs can drive multiple line inputs with no difficulty.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 13th January 2012, 04:09 PM   #6
this is interesting:
How Do I Make a Distribution Amplifier?
expecially this link:
HeadWize - Project: Designing an Opamp Headphone Amplifier (A HeadWize Design Series Paper)
maybe i can use this as a buffer opamp.. ?
Old 13th January 2012, 04:23 PM   #7
rgds, sreten.
1) to learn something new - for me, cause i'm a software eng. -
2) to split the source output signal without losing power 1:1~ signal
Old 13th January 2012, 05:57 PM   #8
Mooly's Avatar
I can understand that.
Try something like this. Also with the addition of two resistors in the feedback network the gain of any buffer can be increased.
Haven't shown supply decoupling but it's good practice to add a small electroylitic across the opamp supply pins.
The TL072 is a good choice for a first project as it's stable and draws little current. Very good performance too.
Old 13th January 2012, 06:53 PM   #9
benb is online now benb  United States
Both good points, but regards to 2) what is the output impedance of the thing you're going to plug into this? What are the input impedances of the things you're going to drive?
An offhand guess at the answers are 1k, 100k, 100k, and 100k. With those numbers, plugging the output directly into one input causes a 1 percent (much less than 1dB) signal loss. Having it drive all three inputs would cause a 3 percent drop, still MUCH less than 1dB. Furthermore there's no active electronics added for the signal to go through.
There still could be other reasons for using a buffer like this. If you have very long cables (maybe 20 feet or more) where the capacitive loading of the cable could reduce the high frequencies, such a thing would help (put this thing at the source and put the long cables at the output) . Do that opanp circuit Mooly just posted, and be sure to include the buildout resistors.
Old 14th January 2012, 03:06 PM   #10
thank you,
if i've understaind
* the 0.47uF cap is to remove dc offset
* the 470K res set the input impedance (the same way the R1 res do in my schematics)
* opamps are in voltage follower configuration
* 68ohm output resistor quite some noise
right?
Can I build up these Darlington transistor if I use two BJT transistor ? gaborbela Parts 9 15th July 2010 06:30 PM
tri-mono active setup? Bad silver Car Audio 3 20th May 2010 02:57 AM
3 Way Tri Active design help SoundLogic Multi-Way 7 19th May 2010 10:57 AM
tri-amping and active xover - TOTAL SEPARATES? tlparker Multi-Way 100 5th October 2006 02:32 AM
line splitter (active/buffered) advice? newmz Solid State 0 23rd April 2003 06:35 PM
Page generated in 0.14566 seconds (83.58% PHP - 16.42% MySQL) with 11 queries
