Go Back   Home > Forums > Source & Line > Analog Line Level
Old 11th January 2012, 11:55 PM   #1
Lightbulb All In One Mixer/PC Project
Hi Everyone...
Well this is my first post to let you know what my plans are,
Basically, I want to build a complete "All In One" Mixer/Scratch/PC, (With folding screen)
I have been busy researching schematics and implementing my own with a few tweaks, I have attached these. I have tried using CAD (hopeless case), so did it using Excel, it gives you an idea and I can easily adjust it.
For the Mixer sofware i will either be using PCDJ or VDJ, hence alot of the main mixer controls will be map'd via MIDI utilising stripped USB Gamepads.
The PC will be a SFF motherboard along with some of the features (USB cards, Dual Monitor outputs CD drive etc)
Internal and external Speaker options/ Headphones(controlled via PC Outputs)
OK now for the help.....
On the schematic, I want to introduce a Reverb circuit for the microphone inputs - All individually controlled (1 in 1 out type of thing)
I dont want and echo, echo, echo but I want a fading away toneeeeeeeeeee lol
Please help, I really have no idea about this bit, I have tried to find an analogue/mono schematic to no joy....
many thanks and thanks for anticipated assistance..
Chris.
Old 12th January 2012, 12:01 AM   #2
nigelwright7557's Avatar
I think VDJ has effects in it so you wont need an external echo circuit.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 12th January 2012, 09:02 AM   #3
Hi and thanks for the response, Vdj does have an effects panel
However I will not be running the Microphones through the PC, inturn VDJ won't have an effect on the vocals, hence the requirement for a Pcb/schematic that is built into the main input schematic.
Chris.
Old 17th January 2012, 05:15 PM   #4
Smile Circuit design (CAD) Updated
Hi All
Have finally got a CAD program (lol) have looked at a few things from what people have been saying, trying to understand them and using the diagnostics on the program I have attached the following schematic..
Am I getting close...
Please please please,, if I have made any errors,, can you explain in the simplest terms possible as I am learning. Please explain certain weird and wonderful terminology lol
thanks and really appreciate all of your help.
Chris.
Old 17th January 2012, 08:33 PM   #5
LM358 pins 2 and 3 need swapping.
Old 17th January 2012, 09:38 PM   #6
Corrected,,, are there any more?? are all the values correct aswell as Capacitors. Do I need to have + polarised caps???
Chris
Old 17th January 2012, 09:43 PM   #7
Chris
Make all capacitors 1uF and above polarised the rest are best none polarised.
Old 18th January 2012, 05:31 PM   #8
Default Okay - Circuit Updated again...lol
Have actioned all suguestions,
hows it looking now??
many thanks
Chris
Old 18th January 2012, 08:06 PM   #9
many thanks
Chris
Looks better.
Anyone else got any comments ?
Old 20th January 2012, 12:15 AM   #10
Speedskater's Avatar
Isn't U1 upside down?
Kevin
PC controlled via USB 6 channel audio mixer with digital volume controls nigelwright7557 Vendor's Bazaar 1 3rd November 2011 02:54 AM
DIY mixer first project Bananasdoom Analog Line Level 2 23rd June 2011 02:18 AM
Ross Powered Mixer PC-4110MT transformer wiring ronthesoundguy Power Supplies 3 12th June 2010 04:11 AM
ESP Project 94A, What am I doing wrong? (Simple Mixer) audiomodder Analog Line Level 1 10th January 2010 08:47 PM
Which audio inerface is best for recording through dj mixer onto a Pc or laptop?? dean ashmore PC Based 4 7th October 2009 07:51 AM
Page generated in 0.09766 seconds (84.83% PHP - 15.17% MySQL) with 11 queries
