Go Back   Home > Forums > Source & Line > Analog Line Level
Old 6th January 2012, 03:34 PM   #1
dirkwright's Avatar
Default output inductor?
A line stage I have has a folded cascode output buffer. There's a 100ohm resistor on the output, as shown in the box. I was wondering if there would be an advantage to replacing it with a small inductor. This is to improve RFI rejection, at least. If this would be a good idea, then how do I pick a good inductance value? Do I go by self resonant frequency, or what? The output could be driving 300ohm headphones or an amp with 10Kohm input impedances.
Old 7th January 2012, 11:16 AM   #2
I would not be keen on using an inductor alone.
I suggest your split the 100r into two 51r in series.
Bypass one of the 51r with a 10uH coil.
Check stability after this mod.
You may have to look at adding a Zobel to complete the Thiele Network.
regards Andrew T.
Old 7th January 2012, 07:47 PM   #3
dirkwright's Avatar
Would you happen to know the function of this particular resistor? Is it protection against shorts on the output or what?
Old 7th January 2012, 07:52 PM   #4
DF96 is offline DF96  England
It is probably to stop the follower from oscillating. Any follower with a capacitive load can become a negative resistance oscillator, due to phase shifts within the devices. An inductor won't help, as the aim is to overcome negative resistance.
Old 7th January 2012, 07:56 PM   #5
dirkwright's Avatar
OK, thanks. I'll leave it there then. I'll have to read up on RFI protection for line level gear.
Old 7th January 2012, 07:58 PM   #6
The resistor may prevent the circuit from causing RFI to other radio users in the vicinity.
Old 7th January 2012, 08:44 PM   #7
dirkwright's Avatar
Do people even put zobel or other networks on the outputs of line level gear? I've never seen any, though that's not saying much.
Old 7th January 2012, 08:49 PM   #8
I've never seen one either.
Old 8th January 2012, 04:07 PM   #9
jcx is online now jcx  United States
the circuit is not a folded cascode - it is basically a complementary double emitter follower - often called a "diamond buffer"
the input Q collectors are bootstrapped by being connected to the opposite out Q emitters - but the collector current isn't used further - so no cascode - only bootstrap
the 100 Ohm R is a good compromise for adequately low line out output Z, load C isolation and some RF decoupling, possible short circuit limiting (check power rating)
with capacitive emitter load an emitter follower shows negative input R and may oscillate - either series R or L can decouple the emitter from capacitive cable load and prevent this negative resistance at the base of the Q
the 47 R may be intended as "base stoppers" and can help with the negative resistance input problem - to oscillate the negative resistance needs a complex impedance input driving the Q base
for headphone drive you may want lower output Z, then the parallel inductor or lossy ferrite bead may be useful in giving low Z at audio while increasing thru low RF to a resistive region at mid/hi RF frequencies - you need to select material, core size for the right resistive value over the right RF frequency range, and pay attention to DC bias saturation spec - audio current being "DC" for the RF ferrite performance
Old 9th January 2012, 12:04 AM   #10
dirkwright's Avatar
Yeah, thanks for that. I don't know where I got the idea that this was a folded cascode. No wonder it didn't match up with all the folded cascodes I looked at on Google.
OK, I'll try to learn something about using ferrite beads. Thanks for the suggestion. Maybe I shouldn't use this to drive headphones anyway.
Thanks very much for your time and helpful suggestions.
Function of Output Inductor caesar148 Solid State 360 19th April 2010 09:01 AM
output inductor in ta2020 garbage Class D 8 9th September 2005 01:20 AM
Source for output air cor output inductor?? sam9 Solid State 7 19th January 2004 02:25 AM
Page generated in 0.12443 seconds (79.70% PHP - 20.30% MySQL) with 11 queries
