Pumpkin Problems - Page 4 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 30th December 2011, 03:04 PM   #31
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
You have some solid decoupling on the rails. If the PSU runs ok with just a resistive load instead of the Pumpkin, you need to look at the Pumpkin, not the PSU.
Has this circuit been simulated to look at the loop response? I have taken a cursory look and it seems the OLG is quite high (if I am reading the circuit correctly!).
There is no compensation, and with th lead cap in the feedback resistor, matters are only made worse. The other option here is to increase the LTP degeneration resistor- currently at 47 Ohms. Try replacing this with a 500 Ohm pot. If that stops it, it's probably your compensation design that needs a bit of work.
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 30th December 2011, 03:10 PM   #32
KatieandDad's Avatar
I'll give it a go tomorrow. I wonder how many people are happy with this poor design.
Old 30th December 2011, 03:34 PM   #33
Bonsai's Avatar
The open loop gain of this designs about 30 000 assuming a very light output load. You definitely need to compensate it. Try the pot change I mentioned above, and let us know how it affects the oscillation. After this we can take the next step with the compensation design. I am sure this thing can be fixed.
bonsai
Old 31st December 2011, 04:43 PM   #34
BDP is offline BDP  United States
Could you explain where you get the 30,000 OL gain figure?
BDP
Old 31st December 2011, 06:43 PM   #35
Bonsai's Avatar
My Mathis was not too good after 3 glasses of red. It's about 4500 and not 30 000.
Input stage is about 15x and output stage is about 330.
It still needs some serious comp to make it reliably stable IMHO.
bonsai
Old 31st December 2011, 07:04 PM   #36
Thanks for the reply.
That is what I figured. I wonder what the optimum gain figure would be. I think Nelson said that Super Symmetric feedback worked best with simple linear circuits, does that mean lower gain figures? It would be easy to load the output to reduce the gain. Or use degeneration on the sources of Q1 and Q2.
BDP
Old 19th January 2013, 12:38 PM   #37
tonimxp is offline tonimxp  Italy
Default Pumpkin problem Upgrade!
Trying also the craziest things to solve the problem, I finally solved!
I removed R21 10k and it all worked out!
Then i decided to investigate and i found out that there is also a version of Pumpkin using in place of R21 ... U1 LM336Z-5V
Pumpkin Preamp - Perfect for F4
Question... What should I do now leave everything just as it is now, or change something?
Removing R21 can involve some variation on the frequency response / stability of the circuit, or ......
I feel comfortable, listen to music and drink wine?
I hope that this discovery could also help other people in this forum!
Greetings to all.
Old 24th January 2013, 10:53 AM   #38
Default Pumpkin noise problem
Hi Bonsai! I noticed that there are several differences between the schematic 1
( that reflects the reality of my pcb) and schematic 2 .
I noticed that i reconnecting R21 but bringing R22 from 47 to 220 ohm things
got better, then I also connected to the base of Q9 between D4 and D5.
But to be able to adjust the offset between -out and +out i had increase
WR1 from 47 to 220 ohm.
Now Noise is OK! (please see shematic 3)
Strangely I have a gain of 4 instead of 4.7 using R5 and R6 47K and leaving R1
and R3 10K, I also changed C1 and C2 from 5p to 10p.
I think everything I've done.
Now i need a greater extent in the high frequencies, I realized that my Pumki
vs my Emerson is less extensive on high.
Please can you give me some advice for more extension?
I believe that pumpkin can give more.
Thanks Bonsai
Be well!
MiniWatt N3 problems, oscillation thumping and RF/motor problems. Destroyer OS Tubes / Valves 18 6th July 2010 12:14 AM
WTB: Pumpkin Preamp Samfi Swap Meet 6 31st May 2010 03:39 AM
My own Pumpkin preamp - Construction Algar_emi Pass Labs 55 19th January 2009 12:28 PM
Copyright 1999-2017 diyAudio
