Pumpkin Problems
Pumpkin Problems
Old 30th December 2011, 10:22 AM   #21
AndrewT is online now AndrewT  Scotland
Originally Posted by AndrewT View Post
Replace the IN to OUT diode with a 30V Zener.
Originally Posted by KatieandDad View Post
So you were talking about your Zener then, not the one in my circuit.
Yes.
regards Andrew T.
Old 30th December 2011, 10:24 AM   #22
Is there any possibility the Nch and Pch FETs are swapped?
regards Andrew T.
Old 30th December 2011, 10:25 AM   #23
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
I was confused.
I knew that the 10V zener was perfectly safe.
I'm on the point of giving up with the Pumpkins anyway as I cant stop them oscillating. Just going to try the other one to see if its the same.
GRRRRRRRRRRR
Old 30th December 2011, 10:26 AM   #24
In (+) In (0V) and in (-)
Are all shorted on the board.
There is nothing else connected except for the PSU.
Old 30th December 2011, 11:35 AM   #25
Both Pumpkins are exactly the same which almost rules out component failure.
The odd thing is that the regulators are providing a clean +/- 36V into resistive loads.
As soon as a Pumpkin is connected, the 20MHz waveform appears on the supply rails, even when bypassed with 220uF + 220uF + 10uF + 120nF + 220nF.
Old 30th December 2011, 11:36 AM   #26
Funny thing is they "work", they just have this strange "whooshing" noise.
Old 30th December 2011, 01:55 PM   #27
All components are the correct value and the correct way round.
I'm at a complete loss as to why they are oscillating.
I even suspected the 'scope but another shows the same story.
Old 30th December 2011, 01:56 PM   #28
Maybe the excitement of the Pumpkin is this oscillation. Andrew T came up with a different approach saying, maybe they are supposed to oscillate.
Old 30th December 2011, 02:05 PM   #29
Funny how all the "Design Engineers" out there cannot even offer an explanation as to why the Pumpkins are oscillating.
I have a feeling that they all do this and that I am the first to notice it.
Old 30th December 2011, 02:49 PM   #30
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Pumpkin Problems
I would delete one by one the decoupling capacitors hanging off the supply rails on the Pumpkin starting with the 120n & 220n. Checking if the oscillation would back off or even stop. There could be a chance they twist the phase margin of the supplies.
Pumpkin ProblemsHide this!Advertise here!
MiniWatt N3 problems, oscillation thumping and RF/motor problems. Destroyer OS Tubes / Valves 18 6th July 2010 01:14 AM
WTB: Pumpkin Preamp Samfi Swap Meet 6 31st May 2010 04:39 AM
My own Pumpkin preamp - Construction Algar_emi Pass Labs 55 19th January 2009 01:28 PM
