| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#11 | |
SY just beat me to it. Capacitors are often nearer perfection than transformers, and are certainly cheaper. A good rule of thumb is: use the appropriate component for the task in hand.
A good thing to remember is that nothing can add to the quality of a signal, but plenty of things can damage the quality of a signal. The best we can do is to minimise the damage. Some of the things people do to avoid things that frighten them (e.g. DC servos to avoid coupling capacitors) can be worse than the thing avoided. Quote:
#12 | |
and I want to fret over what coupling cap I use in it because it gives me pleasure to do so
#13 | |
#14 | |
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#15 | |
#16 | |
Regarding bass, I remember reading about this effect: harmonics of a bass note can give the impression that the (missing) fundamental is present. Last edited by DF96; 20th December 2011 at 08:24 PM. Reason: typo |
#17 | ||
![]() Quote:
#18 | |
#19 |
That's the LS3/5A in a nutshell.
If there's a sucker born every minute, where do the rest of them come from? |
#20 |
In Russian it is called Phase Shiftier, because it does not filter itself. But it can be a part of a filter, that actually attenuates. But again, does not eliminate. However, a pair of APFs can be used to create quite deep notch.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. Last edited by Wavebourn; 20th December 2011 at 09:01 PM. |
| FS: Wima & Rifa Film Caps | cowboy99 | Swap Meet | 10 | 28th January 2012 08:39 PM |
| Preffered film caps to replace ceramic caps? | rg12 | Parts | 20 | 2nd September 2010 04:35 PM |
| Wima & Mundorf film caps for sale | fas948 | Swap Meet | 1 | 28th June 2010 11:36 AM |
| 2 Art 351 EQ (31 band w/ subsonic filters) | cdoggy81 | Swap Meet | 2 | 7th October 2008 09:59 PM |
| Wanted: 8.2uf poly or film & foil caps | KevinLee | Swap Meet | 1 | 20th November 2005 08:02 PM |
