Go Back   Home > Forums > Source & Line > Analog Line Level
Old 1st February 2012, 04:17 AM   #41
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
Thorsten:
I might be misremembering; what you describe here makes me think of the phono preamp in the old Hafler 915 preamp.
http://www.hafler.com/techsupport/pd...preamp_man.pdf
Curiously, never hear about anyone "cloning" this ...
mlloyd1
Originally Posted by ThorstenL View Post
If you use a 2SK170BL at Idss you get around 40mA/V transconductance... Use a second J-Fet as Active load and you can easily get 1MOhm load, giving a "near DC Gain" of around 92dB, which if you use this 1M Load as LF determinant of the RIAA EQ allows 72dB Gain. Add a third J-Fet as buffer/follower and you are done.
Ciao T
Old 1st February 2012, 11:04 AM   #42
Previously: Kuei Yang Wang
ThorstenL's Avatar
Originally Posted by mlloyd1 View Post
Thorsten:
There are parallels but the Haffler phono uses feedback Equalisation, my suggestions works feedback free...
Incidentally the Hafler SE-100 or 915 Preamp Schematics show very seriously high performance FET Circuitry. It is a shame this stuff is underappreciated.
The designs are by Jim Strickland (ex Acoustat), to who'm I doff my hat in respect, it is rare that we see simple, innovative and high performance circuitry the way he did his designs.
Ciao T
Old 2nd February 2012, 02:55 AM   #43
mlloyd1's Avatar
i agree. i always liked the 915 line stage preamp, but never had a chance to hear the phono section. i also never heard the SE-100.
mlloyd1
Old 2nd February 2012, 05:41 AM   #44
ThorstenL's Avatar
The SE-100 is basically a 915 with all the electronic jiggery pokery switchery replaced by honest to god mechanical switches:
Ciao T
Old 16th February 2012, 07:10 AM   #45
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
I just wanted to say thanks for the JFET op amp circuit you posted. Back-of-a-napkin it may be but it's sufficient. I get the idea, and certainly the small parts count make it attractive.
I have a load of 2SK170/2SJ74 pairs selected for this kind of Job.
This is a bit of a problem. I've been looking at the current status of through-hole JFETs and, yeah, it's not looking good: End-of-life, not-recommended-for-new-design, out-of-stock, discontinued, not stocked, part number not found...
Mouser right now is down to about a dozen TO-92 n-channel JFET models that are bone-fide active, not OEL. Everything is "low Rds on for switching applications".
I mean, I'm sure I could track some of these down, at least in personal use quantities, but are there any useful-for-audio JFETs still around if one wants to stick with widely available and easy to source parts?
RJM Audio (phonoclone.com / G+)
Old 16th February 2012, 08:05 AM   #46
ThorstenL's Avatar
Nelson (Pass) uses 2SK370 / 2SJ108 which appear current and are similar to the K170/J74 pairing, but use a different process AFAIK, so performance is not identical hence a new number.
They should be close enough for government work though.
Ciao T
DIY AudioMeeting 21/22 MAY in Italy guglielmope Clubs & Events 0 1st May 2011 09:31 PM
Pioneer B20 build - Help Rullknufs Full Range 8 7th November 2010 11:22 AM
New build of Aleph P1.7 preamplifier t3447ml Pass Labs 21 27th March 2008 11:32 AM
Help to build a preamplifier AMR Solid State 2 2nd June 2004 10:23 AM
Page generated in 0.10361 seconds (80.13% PHP - 19.87% MySQL) with 11 queries
