Go Back   Home > Forums > Source & Line > Analog Line Level
Old 16th December 2011, 04:02 AM   #1
Default Adding Phantom Power to old board?
I know......this is a crazy idea usually, with all of the external phantom supplies out there.
I just picked up an old studio master 16 to 4 board and no phantom. Lots of empty spaces in the chassis.
I also have an old fostex 450 crap board and it has this inside of it.
The yellow connector is 2 pins....... 48v and 0v and is labelled "phantom"
The 3 sets of wires blue, yellow, orange all connect to the transformer. If I were to take the transformer and this board and transplant them into the studio master......would there be a way that I could route phantom power to the xlrs?
If so, would I need any additional parts, or just directly connect the 4bv to the pins 2 and 3 of the xlr inputs?
Any help would be appreciated.
Last edited by wintermute; 16th December 2011 at 04:15 AM. Reason: image resized and attached.
Old 16th December 2011, 01:26 PM   #2
This should do the trick. You may need to change the the gain of the mixer to accommodate the mics you are using. E
Old 16th December 2011, 01:55 PM   #3
I had an old Fostex 450 and I replaced all of the opamps and what a world of difference it made.
It gave my Mackie 32-8 a run for its money and sounded very nice after the mod.
jer
Old 16th December 2011, 02:01 PM   #4
Use 12 volts for the phantom supply and then all you need to do is add the two resistors to each input.
Old 6th February 2012, 11:29 AM   #5
jer
I just bought a Fostex 450 board and I'm thinking of modifying (updating it). What would you recommend? Changing mic pre caps, opamp change. Basically I'd want noise to go down, but more or less keep the overall character of the board..if possible.. Any recommendation would be greatly appreciated..
Power LED from 48 volt phantom power TheFixer Parts 74 16th September 2011 05:00 AM
How to *use* phantom power? .rhavin Chip Amps 12 1st September 2010 09:08 AM
DEQ2496 for phantom power? mazeroth Multi-Way 10 5th January 2006 04:51 PM
adding caps and snubber network to LM3875 power board quickshift Power Supplies 0 19th August 2005 02:12 PM
Using the phantom power Gabevee Instruments and Amps 2 29th July 2005 05:32 AM
Page generated in 0.12680 seconds (66.11% PHP - 33.89% MySQL) with 11 queries
