| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
I am looking to upgrade the volume control on my current Buffalo II DAC. Presently I am using the Volumite board for digital volume control. I recently did a listening test and found that I prefer a simple resistor voltage divider for low volume listening as it seemed more realistic or natural. It was subtle, but noticeable.
As further background information, I am building a circuit board to provide an op-amp based high/low filters for subwoofer output and line switching for home theatre bypass. I am seeking an analog volume control now and there seem to be three different options: 1. Stepped attenuator (TPA Joshua Tree). This has the benefit of being something I could easily remote control. It requires a balanced to single ended converter and an output buffer before going to the filter board. There are a number of options here as well besides the one named above. 2. Transformer Volume Control (Sowter 9335). This seems to eliminate the need for both the bal-se conversion and output buffer. I have been reading very good things about transformers lately and am interested in experimenting with them. It is much more expensive which would suck if I am not happy with it. It also requires a relatively expensive switch to work. 3. Something like a Light-Dependant Resistor. This sounds fairly complicated and I am just including it for completeness. I would need a very good reason to try this. Also requires the bal-se and buffer. Is there anyone here who has tried the above and can comment on the sonic qualities of the different methods and their preference? Is there anything I missed that I should consider? Also, I am using a Legato 3.1 output stage if that makes a difference. Amplification is by Emotiva and I will be adjusting the Legato for ~0 dBu output to match the amps sensitivity. Forgive me if this has been asked before… if so, good links would be appreciated. Thanks for your help. |
#2 | |
Previously: Kuei Yang Wang
Advantage - dirt cheap to make. Disadvantage you always have a ton of relays stringed up and loads of resistors at any sensible level. This maximises the audibility of any possible problems created by them. In many ways a really good potentiometer can sound better. Then again, Conrad Johnson uses them in very highly reviewed line stages, so they cannot be THAT bad. Still, a better option would be to just use a single fixed series resistor and to use as many relays as you will want steps and suitable shunt resistors (which gets a bit difficult at 71 1dB Steps, but managable at for example 32 2dB steps). This is like the old Audio Synthesis "Passion" Passive Pre. More complex matrixes may be used to trade off number of resistors and relays involved for a given number of steps. Sitches can be made via relays or motorised rotary switches to be remote controllable. I personally like TVC's very well, but not all transformers are made equal. Some have measured results that better most (if not all) active and pure resistor solutions, others measure much worse. Cost is invariably very high compared to all other options. If cost is no objective and I can have the best available it would be my choice. These work quite well and are nowhere near as daunting to implemented (type "Lightspeed" into the search here). They have a big advantage in that they lack any mechanical contacts in the audio circuits and can be used with a cheap generic (and easily remoted) pot as control. On the downside, their resistance is heavily voltage dependent and thus makes them problematic when handling AC signals. Normally very high levels distortion are observed. There are possible circuit tricks to cancel much of this, but they are getting complex. Another issue is that LED's and resistors (or whole LED/LDR combo's) need to be matched to bet a good level of balance. across the adjustment range. Some people have claimed sonic miracles for LDR based Attenuators, the ones I have encountered, both DIY types and those build into commercial gear had more drawbacks than I percieved sonic advantages... Some electronic Chip attenuators (not the common ones though) can perform also very well if implemented right, certainly up to the level of a "Joshua Tree" implemented with generic resistors and relay Ciao Ts. |
#3 |
Thanks for the info. I appreciate it. Do you have any experience with the Sowter or further recommendations for TVC? I haven't been able to find to much info on them.
#4 | |
Ciao T |
#5 |
Hi ThorstenL, I found a really old post by you describing some history to the transformer volume controls. Pretty interesting read. It is too bad the S&B TX-102 are out of business. I am still leaning towards a TVC, but the Sowters have been compared to the S&B a few times and it seems the S&B were always ahead.
Any other thoughts on the TVC? Anybody try the Silk? |
#6 |
#7 |
Hi
I use a TVC for years now and I'm happy with it. For me it's the best volume control you can use but you have to take care about some rules: Ratio of output impedance of your DAC regarding input impedance of your amplifier (for example 600 ohm into 10Kohm). Choose an TVC which owns a high inductivity in the bass frequencies that the dynamics will be preserved. Best is to use an autoformer which is a transformer using only one winding of a transformer and you get a better signal transformation because of the absence of the magnetic coupling from primary to secondary. To answer your question ahead I use the Tribute Volume Control. Its inductivity is 150H and it works well to 5Vrms. Please have a look on their website and I attached an image from the unit because it's unice that the switch is included: Tribute audio transformers Last edited by Joao@AltheaMusica; 15th December 2011 at 08:52 AM. Reason: Add some information |
#8 |
Well, the DAC Chip in your Buffalo has the ability to output 6V Peak-Peak from a very low source impedance (50 Ohm IIRC) and can drive a dead short, so it is perfect to connect directly to the TVC and to cut any added stages out, they cannot improve the sound quality and basically have no real job any longer. In this case you cannot use a AVC but a real TVC is needed, yet the results are quite exceptional. I have not measured the Silk's primary inductance, but I can do so, they claim over 1KH (> 1,000H) which if it can be confirmed puts them well past good and bad for most applications, IIRC the S&B ones where 800H... As a rule, the higher your source impedance the greater the potential mismatch issues. I found at least with S&B several KOhm source impedance where no real limitation. Ciao T |
#9 |
The Silk TVC has an interesting selection of taps. As I a lot of my music listening at low volumes the lowest end of the scale is important. I was considering using the Legato with an I/V resistor set to produce low enough voltage so that I could achieve the right output for night listening. This is one area that made me consider a stepped attenuator I this first place. Given the amount of attenuation I use, I am already concerned about the reduced range available on a TVC compared to a resistive attenuator.
Also, as I am considering a balanced to single ended conversion a strength of the TVC an autotransformer would have this going against it. It would have to be really good to overcome this. |
#10 | |
Let's for example take a Speaker with 87dB/2.83V/1m sensitivity and an Amplifier with 32dB Gain and 200W RMS/8 Ohm maximum power... This produces rated power with 1V. For 3m listening distance and the normal levels of crest factor this means the average (not peak) SPL will be around 93dB and need 6dB Attenuation. With 48dB attenuation the SPL will be around 51dB... This is pretty quiet. You can try by rigging up a quick resistor attenuator with 46dB Attenuation (10K + 51R) and see if this is quiet enough. Ciao T |
| Digital volume control question | beamsjr | Chip Amps | 3 | 17th January 2012 02:13 AM |
| Aleph P 1.7 Volume Control Question | toufu | Pass Labs | 5 | 3rd December 2011 11:57 PM |
| Probably a simple question, regarding volume control | Fowlet | Analog Line Level | 2 | 26th September 2010 05:36 PM |
| Volume control question | electric eric | Parts | 3 | 20th September 2005 02:58 AM |
| volume control question | bonsai171 | Solid State | 4 | 25th January 2004 05:15 PM |
| Page generated in 0.14058 seconds (83.61% PHP - 16.39% MySQL) with 11 queries |
